Quantcast Headac3he: Need Help with Delay - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
12-20-2003, 12:38 PM
bigggt bigggt is offline
Hi this isin't the first time this happened but i still can't figure ti out.
I had a mpeg music video and converted it to avi usinf huffyuv and everything was still in sync.
Now the problem is when i used headache(the same settings as when i do a movie)the song doesn't start until 14 seconds.
any ideas
Thanx
Site Staff / Ad Manager
12-20-2003, 12:45 PM
Dialhot Dialhot is offline
14 seconds ? THAT's a delay !
Normally you can know the delay used into an avi using Gspot. The information is given in the panel "Stream Type and A/V Interleave".
You have a region called I/L indicating for instance "NG=1008 ms" for a negative delay of 1008 ms, or "p=480" for a positive delay of 480 ms.
That is normally the value to use in headac3che when you convert the audio.
I hope that will help.
12-20-2003, 01:51 PM
Thanx Dialhot but i mis stated my question i think,there is no delay anywhere except when i make the mp2 file with headache.
The avi is normal with no delay but when i convert the wav to mp2 with headache the music doesn't start until 14 seconds
12-20-2003, 01:57 PM
That's not really an explanation but did you tried to use besweet on that wav ?
12-20-2003, 02:32 PM
Ok i used besweet and when i play the file in winamp its perfect but now i have a different problem when i multiplex with bbmpeg or tempge i get no sound at all.
I now remember whenever i used besweet i could never get the audio to work after its multiplexed
Here is my besweet settings
"C:\Temp\BeSweetv1.4\BeSweet.exe" -core( -input "C:\Temp\music.wav" -output "C:\Temp\music.mp2" -logfilea "C:\TEMP\BESWEET GUI V0.6 B83\BeSweet.log" ) -ota( -hybridgain ) -toolame( -m s -b 192 -e ) -profile( ~~~~~ Default Profile ~~~~~ )
Please tell me if something is wrong and how to correct it,i really have no idea what i'm doing with besweet
Thanx
12-20-2003, 02:40 PM
First, use mp2enc and not toolame : in "2lame" tab of besweetGui, you have a setting "Engine". Check MP2ENC.
Second, do not use hybridgain but 2 pass normalization : in besweet tab, see wqhere "hybridgain" is, and choose "Pregain" and then "Normalize to" next to this setting and finally "100%" in the third setting on the same line
Third (optional, depend on your player) : resample to 44.1 Khz : in SSRC tab, check "Set Sampling Rate of Output File to :" and set 44100 as value. Then in besweet tab, check the box SSRC.
The comand should look like this now :
"C:\Program Files\Autres Applications\BeSweet\BeSweet.exe" -core( -input "z:\KVCD\Brasil.wav" -output "z:\KVCD\Brasil.mp2" -logfile "C:\Program Files\Autres Applications\BeSweet\BeSweet.log" ) -ota( -g max ) -mp2enc( -m s -b 128 ) -profile( ~~~~~ Default Profile ~~~~~ )
12-20-2003, 05:36 PM
Thanx Dialhot working perfect now ,are these settings for besweet that i should use all the time
Thanx again
12-20-2003, 08:12 PM
Yes they are. Just remember to change the bitrate in the 2lame tab according to your needs (112, 128, 192...)
Delay no bbmpeg vinicius Conversão e Codificação de Vídeo (Português) 0 08-26-2004 08:08 PM
DVD2AVI: Delay 29ms Bchteam Video Encoding and Conversion 13 07-29-2004 06:09 AM
AC3 delay when authoring DVDs? Dam0 Authoring VCD, DVD, Blu-ray 0 07-27-2004 05:16 AM
KDVD: How to add ac3 audio delay? dooger2 Video Encoding and Conversion 2 12-05-2003 05:09 AM
KDVD: AC3 has audio delay? J-Wo Video Encoding and Conversion 4 10-24-2003 06:02 PM
All times are GMT -5. The time now is 04:45 AM  —  vBulletin © Jelsoft Enterprises Ltd
