Quantcast KVCD: Not Enough Space to Burn this Compilation? - digitalFAQ.com Forums [Archives]
01-09-2004, 04:40 PM
Adder Adder is offline
hey all
I am trying to burn my finished encoding of Matrix Reloaded using Nero burning rom version 6 and its saying there isn't enough space to burn this compelation, my final encoding has come out at 795mb (833,687,556) i thought upto 800mb in mode2 was allowed?
anyone know why nero is refusing this i never had these problems with nero in the past
cheers.
Site Staff / Ad Manager
01-09-2004, 04:42 PM
kwag kwag is offline
Hi Adder,
Try burning with VCDEasy.
If you get the same error, demux your mpeg, and remux with TMPEG.
Try it that way
-kwag
01-09-2004, 05:17 PM
hey kwag
thanks for quick response.
Isn't latest VCDEasy limited to no more than 400mb files
can you explain how i would mux in tmpeg i never done this before
cheers.
01-09-2004, 05:25 PM
Boulder Boulder is offline
You should get the last free VCDEasy from the official site (v1.5.2 IIRC). It doesn't have any such limits.
01-09-2004, 06:01 PM
hey guys
Thanks for your suggestions i pin pointed the problem!!
It was BBMpeg which i use to multiplex my audio and video together the settings were totally wrong must have reset somehow i corrected these remultiplexed and everything is burning now in nero nero is even saying the file is 801mb!!
so why would BBMpeg cause so much hassle just by settings puzzles me but you guys probably understand. heh
cheers.
01-09-2004, 07:56 PM
Dialhot Dialhot is offline
isn't there a RED warning in bbmpeg saying "do not modify anything except if you know what you are doing" ?
You know the reason now
01-09-2004, 09:43 PM
buddyslack buddyslack is offline
I've had problems with mpeg files over 794 meg, sometimes they have needed to be overburnt by 1 second ect.
So I make sure all my s/kvcd mpeg files are <795meg
after I've made them bin/cue they come out around 804meg
Manual Compilation of Two KDVDs with TMPGEnc Blubear Video Encoding and Conversion 3 08-17-2004 02:28 AM
How to insert regular or modified AC3 track into SVCD compilation? Hydeus Authoring VCD, DVD, Blu-ray 7 03-12-2004 07:05 PM
KVCD: Space needed on PC? zippy Video Encoding and Conversion 1 12-14-2003 11:20 AM
KVCD: 1-18-3-1-60 Gop = save 6.3% space? bman Video Encoding and Conversion 4 06-30-2002 01:08 AM
KVCD: 178 Minutes at 686MB of space? PToN Video Encoding and Conversion 5 05-23-2002 07:22 AM
All times are GMT -5. The time now is 05:14 PM  —  vBulletin © Jelsoft Enterprises Ltd
