Quantcast Headac3he: Headac3he Crashing in XP Pro, Codec Issue? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
01-28-2004, 05:54 PM
Max0d Max0d is offline
I was just wondering if anyone has come accross a reason why headac3he crashes as soon as it is opened in XP. Befoe I re-installed OS it was fine so I assume it must be becasue of a codec issue making it crash (as I have come across using other application). Does anyone know why it may be happening all of a sudden?
Site Staff / Ad Manager
01-28-2004, 05:59 PM
kwag kwag is offline
Make sure you have downloaded the proper HeadAC3he .DLLs for your CPU.
You must have the correct ones, or you'll crash.
-kwag
02-03-2004, 11:42 AM
I have all the correct dll's for my CPU. The same version and settings work on my system under win 2000, they used to work under XP but not anymore.
HeadAC3he: Does HeadAc3he auto-fix ac3 delays on conversion? Fluffbutt Audio Conversion 2 04-27-2004 11:53 AM
HeadAC3he: 48kHz to 44.1khz issue big Audio Conversion 4 03-17-2004 08:53 AM
HeadAC3he: HeadAC3he only loads or recognizes half of the file? Raynaldo Audio Conversion 4 05-27-2003 09:40 PM
HeadAC3he: HeadAC3he doesn't convert MPG or WAV audio properly! PyRoMaNiA Audio Conversion 5 04-21-2003 03:52 PM
HeadAC3he: Empty archive after downloading HeadAC3he?? Help!! Reno Audio Conversion 6 04-09-2003 04:37 PM
All times are GMT -5. The time now is 05:11 PM  —  vBulletin © Jelsoft Enterprises Ltd
