Quantcast Why can't Muxed Subtitles be Played on PC ? - digitalFAQ.com Forums [Archives]
02-20-2004, 05:04 PM
Hydeus Hydeus is offline
I know that subtitles muxed into mpeg file are played only on standalones, and I have no problem with that (there was with position but I solved this out).
My question is, why they can't be played on PC. Is there any reason that sofware players can't play them?
__________________
Go for SECAM =)
Site Staff / Ad Manager
02-20-2004, 06:37 PM
Dialhot Dialhot is offline
VCD/SVCD capable player handle subtitlres with no problem. WinDVD or PowerDVD for instance. Where did you read they can't ?
02-20-2004, 06:43 PM
I think it was on "How to" by GRF, and in fact I can't watch them on PowerDVD
EDIT: This is the link. Scroll to the very end.
__________________
Go for SECAM =)
02-21-2004, 06:48 AM
rds_correia rds_correia is offline
Hi guys,
In fact I backup Hydeus on this one because I've seen this written all over the web too. Search for it here at kvcd or at vcdhelp or other sites and you'll see you'll find it too.
And the problem is that WinDVD & PowerDVD don't show these subs at all when I try.
So I never thought these were supposed to show subs because I had already read that it was impossible, for either svcd or dvd.
So tell us about your subs experience, Phil.
Should we be able to see those subs or only the hard encoded ones with vobsub?
Cheers
__________________
Rui
02-21-2004, 04:38 PM
I will retest this because for the moment I'm not sure. I didn't do selectable subtitles on my SVCD because my standalone do not support them. So my memories are on test I did years ago.
I'll tell you.
02-23-2004, 04:22 AM
mistermickster mistermickster is offline
Isn't it something to do with, you can't have Subtitles AND PBC on at the same time
__________________
MisterMickster
02-28-2004, 06:57 AM
So we have nothing new. Subtitles are PC-unwatchable. Sad
__________________
Go for SECAM =)
02-28-2004, 07:59 AM
Hi Hydeus,
As far as I am aware, you're right.
In fact those days I didn't tested it much as SO MANY people was saying that it couldn't be done.
I'm over the SVCD era now that I moved to KDVD where we have switchable subs.
Haven't you done the same, yet?
Cheers
__________________
Rui
02-28-2004, 09:32 AM
Post me some simple how2. I'm now at SVCD resolution cause fullDVD res is too much bitrate hungry So try to keep that in mind. Thx
__________________
Go for SECAM =)
03-03-2004, 05:25 AM
Ok. Vmesquita may found something here (and wrong placed ). I have not tested this feature yet.
__________________
Go for SECAM =)
03-23-2004, 08:37 AM
DiCE DiCE is offline
Try to use BS PLAYER to view the subtitles
07-19-2004, 02:22 PM
johnson636 johnson636 is offline
Send a message via Yahoo to johnson636
Hello guys, I know that this thread started in Feb. But as I was reading through the thread< I saw that it ended with the notion that pc's cant play subtitles.
He is once again correct; I watch movies that have subtitles all the time on my pc. You have to have a subtitle filter installed which should come with the latest version of PowerDVD, WMV player, or whatever app you use to watch your movies. If you have a sub filter installed and the subs are merged with you dvd movie, avi, or mpeg file, just load and it should play fine. If you have your avi or mpeg file serperate from your sub, just name the sub file with the same name as your avi or mpeg file and put them into the same folder (movie file name= my movie, sub name= my movie). Then open the movie using your desired player (I personally use WMP and PowerDVD) and the player will know to load both the files and the subs should show up in the movie
Once again, I know this thread started in Feb. and if you've already found answer, great; I just thought I could help, thats all.
07-19-2004, 02:28 PM
Prodater64 Prodater64 is offline
I think they was talking about muxed subtitles. This ones are multiplexed together with audio and video streams in mpeg2 files. This kind of subtitles only can be managed by standalones or by vlc player as i know. Maybe in last time another software could be reach this ability.
After muxed m2v and mp2 to mpg in tmpgenc, mpg cannot play? toysoldier Video Encoding and Conversion 5 03-03-2005 07:19 AM
Bitrates: Muxed stream won't fit in CD/DVD rds_correia Video Encoding and Conversion 10 01-02-2004 10:36 AM
Audio out of sync when muxed with 3:2 pulldown MPEG-1 gvarney Video Encoding and Conversion 3 07-25-2003 09:51 AM
Last few seconds not played back? girv Players, DVRs, Media Centers 0 01-20-2003 07:38 AM
CD that will be played both on a PC and on a standalone DVD player ? Lula1 Players, DVRs, Media Centers 12 09-16-2002 12:11 PM
All times are GMT -5. The time now is 08:16 PM  —  vBulletin © Jelsoft Enterprises Ltd
