Quantcast Besweet: Nothing Happens in Besweet, Audio Not Converted - digitalFAQ.com Forums [Archives]
03-03-2004, 11:36 AM
wgamer wgamer is offline
i am trying to convert audio directly from avi into mp2
so i start besweet;select wizard; select input;then ouput type; output mode; frc presets ( i am not using any conversion) then GO
...........nothing happens the lame.exe and lame_enc.dll are in the
same directory
so what i am doing wrong?
Site Staff / Ad Manager
03-03-2004, 11:40 AM
Dialhot Dialhot is offline
Copy the command line and paste it into a Dos window. You will see imediatly the error.
BeSweet Wizard: Besweet log file not created Madcatz265 Audio Conversion 5 08-10-2004 06:25 PM
BeSweet: Various setting in besweet - normalize, downmix? zagor Audio Conversion 1 06-14-2004 04:11 PM
BeSweet: Join two audio files by Besweet? dongxu Audio Conversion 2 04-02-2004 03:15 AM
BeSweet: Besweet crashes when trying to convert OGG files rs008f Audio Conversion 29 03-04-2004 02:54 PM
BeSweet: Adjusting volume in BeSweet (with AC3 Machine) syk2c11 Audio Conversion 0 12-09-2002 10:16 PM
All times are GMT -5. The time now is 09:57 AM  —  vBulletin © Jelsoft Enterprises Ltd
