Quantcast CCE MPEG-2 Video Re-Encoded by Ulead DVD Movie Factory? - digitalFAQ.com Forums [Archives]
03-08-2004, 11:15 AM
johnson636 johnson636 is offline
Send a message via Yahoo to johnson636
Can anyone tell me why would an avi file that was converted to MPEG2 using CCE has to be once again converted by ulead dvd movie factory 2 before the actual dvd vob files are created. But on the other hand After converting that same avi to MPEG2 using TMPGENC, Ulead dvd movie factory 2 does not have to convert the MPEG2 a second time, but goes right to creating the vob dvd files
If you are reading this post and you have successfully created mpeg2 files using CCE and created dvd files without that app having to convert the mpeg2 a second time, please tell me what dvd app you used.
Site Staff / Ad Manager
03-08-2004, 11:55 AM
incredible incredible is offline
Send a message via ICQ to incredible
Maybe you did set in CCE encoding settings which does not allow ulead to author a DVD!? Well ...
Do switch to "DVDlab" or "TmpgEnc DVD author". As these are the apps most used in here to author mono-lingual KDVDs.
Ulead DVD Movie Factory forced re-encode, and audio out of sync? ragrost Authoring VCD, DVD, Blu-ray 0 08-13-2004 10:31 PM
Menu in kvcd con Ulead movie factory 2 eugenioturco Convertire e Codifica dei Video (Italiano) 0 12-30-2003 04:52 AM
Ulead Movie Factory does not accept MPEG1 from KVCDx3 Lula1 Authoring VCD, DVD, Blu-ray 3 09-23-2002 02:56 PM
Recording Video in Huffyuv with Ulead video studio SE? mpierce Video Capturing / Recording 0 09-06-2002 12:34 PM
Encode settings in DVD Movie Factory? Bud Video Encoding and Conversion 5 06-18-2002 11:49 AM
All times are GMT -5. The time now is 03:06 AM  —  vBulletin © Jelsoft Enterprises Ltd
