03-13-2004, 08:51 PM
Hi, I haven`t been here for a while.
I am using dvd lab to author my movie, but find that after compiling, the movie comes out jittery.
The audio and video are sync`d, but every now and then you see a lttle jitter. It does this on the Pc, as well on my Dvd player, so I`m thinking that there is a special tweak or config or something i`m doing wrong.
Please help.
P.S : The converted files don`t jitter.
Site Staff / Ad Manager
03-13-2004, 09:34 PM
Seems to me it's a frame rate or pulldown issue.
What are your source specifications
-kwag
03-13-2004, 09:47 PM
source 16:9 pal
03-13-2004, 10:50 PM
Make up your mind
-kwag
03-13-2004, 11:02 PM
When I Multiplex with bbmpeg and view the file in Powerdvd, there is no jitter.
When I let dvd lab multiplex and compile there is jitter.
When I drag my already multiplexed file into dvd lab and say don`t extract and multiplex, and then compile.
I view the vob file and it jitters.
Now the problem is with dvd lab, I need to know if i`m doing something wrong?
03-13-2004, 11:09 PM
Ok, have you tried dragging your MPEG files into TMPEG DVD Author, and see if you get the same behaviour
-kwag
03-13-2004, 11:25 PM
I`ll try
03-14-2004, 04:07 AM
Now it`s perfect , Dvd Lab sucks big time
03-14-2004, 01:14 PM
If I'm not wrong there is a cjeck box "reduce Jitter" in DVD-Lab compile window. I think you already check it, but just to be use you saw it...
03-15-2004, 03:50 AM
I tried it all, with and without all different settings, but thanks for the advice.
I`ll stck to tmpg from now on.
03-15-2004, 05:17 AM
DID you set up DVDlab to your specific Country Video standard (PAL, NTSC) ????
03-16-2004, 02:37 AM
Like I said I tried everything.
Thanks for the help.
03-28-2004, 02:26 PM
I disagree I think DVD Lab is awesome!
I recently ripped two of my DVD's to fit them onto one KDVD and I used DVD-Lab to create a flash menu and sub menus which has motion backgrounds and scene selections screens etc.
I have PAL-I source and the menu and movies came out excellent and the menus looked cool.
It took me a while to get to grips with it but once I followed the tutorials on their site I finally authored a nice little DVD.
__________________
Regards.
Michael.
06-21-2004, 03:55 AM
Read the post, nobody said that Dvdlab does not author nicely, cause it does. The problem is jitters after compiling.
All times are GMT -5. The time now is 06:18 AM — vBulletin © Jelsoft Enterprises Ltd
