Quantcast Subtitles: Trying to do Perm Subtitles for SKVCD - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Subtitles
03-20-2004, 03:17 AM
KYUSS KYUSS is offline
hi guys here's my script
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\MPEG2D~1.DLL")
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\AVISYN~2.DLL")
mpeg2source("D:\DVD2SV~1\DVD2AV~1.D2V")
nf=0
GripCrop(352, 360+60+60, overscan=1, source_anamorphic=true, dest_anamorphic=false)
GripSize(resizer="BiCubicResize")
Undot()
Asharp(1, 4)
STMedianFilter(8, 32, 0, 0 )
MergeChroma(blur(1.58))
MergeLuma(blur(0.1))
SwitchThreshold = (Width<=352) ? 4 : (Width<=480) ? 3 : 2
ScriptClip("nf = round(YDifferenceToNext())"+chr(13)+ "((nf >= SwitchThreshold) && (nf < 30)) ? unfilter(-(fmin(nf*2,100)),-(fmin(nf*2,100))) : TemporalCleaner(6+nf,11+nf) ")
GripBorders()
function fmin(int f1, int f2) { return (f1<f2) ? f1 : f2 }
function ConvertToYUY2(clip c){ return isYV12(c) ? c : convertToYV12(c) }
ConvertToYUY2()
AvisynthSubtitler("D:\DVD2SV~1\Subs\","permsubs.txt")
does this look ok?
encode came out excellent only no subs?!!!!
the proggy i used was dvd2svcd with the dvd2kvcd plugin
is the subs line in the right place?
cheers
KYUSS
Site Staff / Ad Manager
03-20-2004, 09:00 PM
Dialhot Dialhot is offline
Your problem is that AvisynthSubtitler, the line that provides the subtitles, needs to work in YUY2 (that is why there is also the line ConvertToYUY2)
The problem is that you (or azel, who made the plugin) took a line from a script of mine that need to work in YV12. That's why you find the line "function ConvertToYUY2" that in fact, force a convert in YV12 !
Just remove this line ("function ConvertToYUY2(clip c){ return isYV12(c) ? c : convertToYV12(c) } ") and I think all will be ok !
03-21-2004, 09:02 AM
cheers m8
i will give that a try tonight
thanks
KYUSS
03-22-2004, 10:14 AM
that worked a treat m8
thank you
KYUSS
03-22-2004, 10:17 AM
Great . Just keep in mind that YUY2 mode is 30% slower than YV12 and a little bit less performant. So do not use this mode for all your jobs but just the ones where you need tu use permsubs.
03-22-2004, 06:38 PM
will do m8..........
i do most of my conversions overnight now so time aint really a problem
but i will heed your warning about the script not performing as well with that line removed
for now i need perm subs so i'll just take the 30% speed hit whilst i am in slumber
thanks again for the help m8
KYUSS
Subtitles: How do I add subs in DVD-Lab Pro? Zyphon Subtitles 6 07-21-2004 07:51 AM
Subtitles: How to resize subs? raptor2000 Subtitles 1 01-18-2004 01:11 AM
Subtitles: Adding subs with acp rafa Subtitles 0 10-07-2003 04:37 PM
DVD2SVCD: Perm subs + DVD2SVCD + Avi/Divx conversion Paulus Video Encoding and Conversion 3 09-13-2003 05:41 AM
Subtitles: Cannot find any subs on this DVD audioslave Subtitles 8 07-15-2003 12:51 PM
All times are GMT -5. The time now is 05:35 PM  —  vBulletin © Jelsoft Enterprises Ltd
