Quantcast Burning Jumps to 20% Using Nero 6, then Fails Shortly After - digitalFAQ.com Forums [Archives]
03-30-2004, 10:46 PM
eonbluez eonbluez is offline
Burning jumps to 20% using Nero 6 then fails shortly after, no matter which speed i burn at. I unchecked the standard compliance box, but it still jumps ahead... do i need to install any kvcd codec or anything to make this work?
Site Staff / Ad Manager
03-31-2004, 03:15 AM
Dialhot Dialhot is offline
No. But you have to install a Nero version that works with your burner (and vice-versa).
Nero insn't a full universal tool. Some burner brands do not like it (and the opposite).
Burning a KVCD using Nero sbansal Authoring VCD, DVD, Blu-ray 7 12-11-2005 06:55 PM
Burning m1v files with Nero? dastott Authoring VCD, DVD, Blu-ray 4 10-16-2004 09:13 AM
Burning with Nero 5.5.1.8 ZTM Authoring VCD, DVD, Blu-ray 5 12-25-2003 09:22 PM
Problem after burning with Nero 5 Greig Authoring VCD, DVD, Blu-ray 1 11-26-2003 09:41 AM
Need Help Burning KDVD Using Nero KVCDs Authoring VCD, DVD, Blu-ray 1 06-22-2002 12:40 PM
All times are GMT -5. The time now is 12:13 AM  —  vBulletin © Jelsoft Enterprises Ltd
