Quantcast Nimo Codec Pack messed up my Video Capturing! - digitalFAQ.com Forums [Archives]
08-15-2002, 10:37 AM
bapski bapski is offline
few weeks back i had a problem with my ms 4.25.. i cannot "produce" my captured videos... i might have just stumbled on the culprit...
just now i did a full installation of nimo codec pack. . . and when i tested ms 4.25 it would not work..... after uninstalling it i was able to use my ms 4.25 again...
the reason i installed the nimo codec pack was because i had errors with tmpgenc 2.57 plus it says it cannot recognize the AC3 file....
QUESTION: if i should install nimo.. which of the codecs should i install?
Site Staff / Ad Manager
08-16-2002, 11:19 AM
el_mero_zooter el_mero_zooter is offline
Send a message via MSN to el_mero_zooter
Bap,
soundz probably like it could be that ur rig is needing some ac3 filters.
try some from DDigest and see if that getz u going...
http://www.digital-digest.com/dvd/do...ng_plugin.html
or try a search on google for 'AC3 Filters'
ztr
Anway way to fix a messed up Mpeg video and audio? NittoLive Video Encoding and Conversion 3 04-22-2006 05:39 PM
Kazaa lite codec pack pepolyno Conversão e Codificação de Vídeo (Português) 5 06-29-2004 10:07 AM
Problème Pack Codec Nono Conversion et d'Encodage de Vidéo (Français) 1 02-11-2004 04:24 AM
DVD decrypting - video is messed up? Dmaster87 Video Encoding and Conversion 1 01-13-2004 06:31 AM
Codecs: ACE Mega Codec Pack Professional jorel Video Encoding and Conversion 0 07-16-2003 01:17 PM
All times are GMT -5. The time now is 06:18 PM  —  vBulletin © Jelsoft Enterprises Ltd
