Quantcast Ready for Dual Layer DVD Authoring? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
05-20-2004, 12:19 PM
syk2c11 syk2c11 is offline
Hi there,
I have been looking for the authoring program which accepts VOBs (with 2 subtitles and just 1 soundtrack). What I am trying to do is to transcode 2 movies (by using DVD Shrink) and burn it onto ONE dual layer DVD+R (I know dual layer blank disc is still not available yet, but dual layer burner is just released).
Here is the problem: I use TMPGEnc DVD Author most of the time and I know it accepts VOBs. I did a test by importing just ONE movie in VOBs (created by DVD Shrink), created a very simple menu (with just a button and a background picture), the new set of VOBs (with the menu that I created) created by TMPGEnc DVD Author, there was NO subtitle at all, it just gone! I viewed it in PowerDVD, no subtitle for selection. I burned it onto DVD-/+RW, still, no subtitle at all. Where did the subtitle go? The source VOBs (i.e. the one created by DVD Shrink) played perfectly in PowerDVD, subtitles worked perfectly. So, I suspect TMPGEnc DVD Author is the culprit. Any idea? Thanks in advance.
Site Staff / Ad Manager
05-20-2004, 02:05 PM
Dialhot Dialhot is offline
Tmpgenc Author does not supports subtibles; See in the spec of the tool.
You need DVDlab Pro au Maestro for that.
Pioneer dual-layer DVD-R recording on single layer A06 jorel Blank Media / Burning Discs 4 10-13-2004 03:22 AM
Blank Discs: DUAL LAYER +R TECHNOLOGY totonho03 Blank Media / Burning Discs 0 10-03-2003 09:00 PM
Dual-layer Audio mpeg VCD? both languages playing at the same time? lanvo Video Encoding and Conversion 3 07-14-2003 11:41 AM
KVCD: ready for fitcd and a script? Bombero0437 Video Encoding and Conversion 4 01-27-2003 08:35 AM
Avisynth: Ready-made scripts?? Reno Avisynth Scripting 0 01-05-2003 10:01 PM
All times are GMT -5. The time now is 11:06 AM  —  vBulletin © Jelsoft Enterprises Ltd
