Quantcast Audio Way Out of Sync on PAL to NTSC Conversion - digitalFAQ.com Forums [Archives]
05-24-2004, 04:56 AM
jshew jshew is offline
On a PAL to NTSC conversion. Did framerate conversion in Script (Moviestacker). Converted the WAV file in BeSweet but when multiplexed with the video the audio begins about 2 secs ahead of the video and just gets progressively worse. Getting to about 2 1/2 minutes ahead after about 60 minutes runtime. What does this seem to indicate?
Site Staff / Ad Manager
05-24-2004, 05:57 AM
Boulder Boulder is offline
It indicates that you didn't do the same conversion to audio.
05-24-2004, 06:07 AM
glent2k3 glent2k3 is offline
Send a message via MSN to glent2k3
your source will be 25fps(0riganl)
to encode to 23 or 29 (to match the video)you have to check to box and select the preset you need. IF you still have a small delay then mux with mplex and delay the audio in the settings tab
__________________
put your liteon dvdr in the bin and buy an NEC 2500A
05-24-2004, 10:05 AM
Dialhot Dialhot is offline
And did you do also the framerate conversion for the AUDIO in besweeet ?
Note: I hope you are going from 23.976 and not from 29.970 !
05-24-2004, 07:41 PM
Yes, the soure is 25.000 fps. I encoded the video with a Moviestacker script, with format conversion selected and the output is 23.976 fps. The audio I did in BeSweet, using the WAV file and doing a framerate conversion from 25.000 to 23.976. The Besweet Log file showed it was successful, so I'm confused??
05-25-2004, 07:06 AM
Check the length in seconds of the wav, the one of the mp2 and the one of the encoded video.
MP2 must be = to video.
And wav should be exactly (length of MP2*23.976/25).
If you don't have this, you did something wrong.
05-25-2004, 05:29 PM
What programs would work to check the length of the encoded video, which is a .m1v file (or is it mpeg) out of TMPGEnc? And to check the length of the .mp2 and original .wav?
05-26-2004, 05:13 AM
simply open then in wmp
(if the length seems not correct for the m1v, you can use avicodec for it).
NTSC to PAL Conversion? khusru Video Encoding and Conversion 6 05-10-2005 08:54 AM
Divx to kvcd conversion audio sync problems? enximex Video Encoding and Conversion 14 10-27-2003 10:18 AM
KVCD: WLA conversion from PAL to NTSC? zero_cool_root Video Encoding and Conversion 1 10-12-2003 05:41 AM
TMPGEnc: Kvcd audio sync problem on pal to ntsc conversion DawnOfTheDuke Video Encoding and Conversion 2 05-30-2003 04:43 PM
Encoding: NTSC to PAL conversion tips needed Tachyon Video Encoding and Conversion 4 06-07-2002 05:08 AM
All times are GMT -5. The time now is 10:33 AM  —  vBulletin © Jelsoft Enterprises Ltd
