08-29-2007, 01:01 AM
Michael Randazzo Michael Randazzo is offline
Does anyone know how to convert MP3's to CD's? If so please email me with instructions. Thanks and God Bless
Michael
Michael Randazzo
08-29-2007, 02:00 AM
manthing manthing is offline
the simplest, but maybe not neccessarily the best option, is to use one of the many mp3 to cd all-in-one solutions.
example: http://www.mp3-cd-converter.com/
and its really a 1-2-3 step process.
but wait for others to chip in with possibly better solutions.
08-29-2007, 03:00 AM
plaidman76 plaidman76 is offline
I used to use programs like Nero, convert the MP3s to Wavs, then burn to a disk.
I don't burn many cds anymore, but now when I do I just use iTunes. Just make a playlist, drag your mp3s into the playlist, put in a blank CD, then click burn. And since you can download iTunes for free if you don't already have it, seems like a good solution to me.
08-29-2007, 03:06 AM
wayshway wayshway is offline
Send a message via AIM to wayshway
You can download the dbpoweramp software for free at: http://www.dbpoweramp.com
I use it all the time for converting FLAC and SHN files to WAVE.
It's really simple to use and will convert it to a wave file in a matter of seconds so you can burn it onto a cd.
08-29-2007, 10:51 AM
Tranzor Tranzor is offline
whatever program you use to burn, I'm sure it has an "audio" option. If so just drag your mp3's on it and burn. 99.999% of all burning apps will convert the mp3s for you during the cd burning process. Their is no need for you to do anything else.
If you want to burn mp3's on a cd while keeping them mp3, then just burn it as a data disc. very simple
08-29-2007, 03:57 PM
I use Nero 6 and make an Audio CD. Just drag the MP3's the audio timeline.
08-30-2007, 06:11 AM
rockman666 rockman666 is offline
Send a message via ICQ to rockman666 Send a message via AIM to rockman666 Send a message via MSN to rockman666 Send a message via Yahoo to rockman666
You could just use Windows Media Player if you want an easy method (yet unbelievably slow at times). Just go to the burn feature and drag the MP3's into the burn list (this is with Media Player 11.....I can't remember if its any different in previous versions).
My Transformers Website - http://www.tfrid.com
08-30-2007, 09:32 AM
ku7uk ku7uk is offline
Use Nero. Its easy. Just select 'Make Audio CD', Then drag and drop the mp3 files into the window, then press 'Burn'. (Oh, and make sure you have a blank cd in your cd writer).
How to convert DVR-MS files to AVI, MPEG-2 or MPEG-4 ? reframmellator Encode, Convert for discs 1 09-02-2009 05:15 AM
Convert .avi to .mpeg (mini DVD and Pinnacle Studio) Dianne Encode, Convert for discs 10 04-11-2009 01:52 AM
How to Convert AC3/MP2 to WAV for Restoring Audio lordsmurf Restore, Filter, Improve Quality 8 03-10-2009 02:42 PM
Convert x to DVD gatch72 Encode, Convert for discs 8 02-22-2008 08:04 AM
Need a program to convert .vob to mpeg. Swingbelly Encode, Convert for discs 3 07-20-2005 04:41 PM
