03-20-2021, 12:39 PM
Zeta83 Zeta83 is offline
I've actually already put in an order for the OEM Intel cooler but I think it's the dual-core model, which appears to be aluminum. How much of a difference is it likely to make? I am using a dual-core processor (Core 2 Duo E7600 3.06GHz) and the computer case is pretty well ventilated. I also haven't returned that Cooler Master yet. Would it be worth the time and trouble to try and get the adapter? Or sending these both back and getting the quad-core cooler?
As far as the hard drives, are there any particular specs I need to look for in order to avoid the compatibility issues I've heard about? I think this board only does SATA 1.
I think I might know a way to convert HUFFYUV to a Mac-usable format, but if it doesn't work, I can make converted copies on the capture PC and send them to the Mac, or send the HUFFYUV files to my Lenovo i5 laptop with Windows 10 instead, right?
04-10-2021, 06:32 PM
For capture systems, I use Apevia 450W PSUs, cheap and quality. Too many people overspend of the PSU, and get a heat box for the money -- double punishment.
Hyper 212 is worth the time/funds, OEM coolers are junk.
For AGP AIW, I think you're fine.
Don't forget the capture drives, 2tb, Seagate suggested. SATA2 is fine, it'll just run slower. PCI expansion is also fine, non-VIA chipsets, and runs at SATA1 speed with full SATA2/3 specs. You can capture to those without issues.
04-14-2021, 03:07 PM
The Intel cooler is installed and is loud.
I might return the unused Hyper 212 and get a Noctua NH-D14 or NH D-15, or possibly another one from this list https://www.quietpc.com/lga775-coolers.
Or I could do this:
https://youtu.be/z9WwujbfBX0
ati aiw radeon, hi8 capture, pc build
ATI TV Wonder USB vs Radeon AIW? Mascis Capture, Record, Transfer 7 06-15-2017 12:09 PM
Difference between ATI All-In-Wonder Radeon and ATI Radeon? dana2 Capture, Record, Transfer 3 11-05-2016 02:54 PM
Will All-in-Wonder HD Radeon HD 3650 do the job metaleonid Capture, Record, Transfer 1 12-14-2014 10:45 PM
Will laptop be powerful enough to capture video? kcmom Project Planning, Workflows 2 04-21-2013 01:08 AM
