08-29-2007, 01:01 AM
Does anyone know how to convert MP3's to CD's? If so please email me with instructions. Thanks and God Bless
Michael
08-29-2007, 02:00 AM
the simplest, but maybe not neccessarily the best option, is to use one of the many mp3 to cd all-in-one solutions.
example: http://www.mp3-cd-converter.com/
and its really a 1-2-3 step process.
but wait for others to chip in with possibly better solutions.
08-29-2007, 03:00 AM
I used to use programs like Nero, convert the MP3s to Wavs, then burn to a disk.
I don't burn many cds anymore, but now when I do I just use iTunes. Just make a playlist, drag your mp3s into the playlist, put in a blank CD, then click burn. And since you can download iTunes for free if you don't already have it, seems like a good solution to me.
08-29-2007, 03:06 AM
You can download the dbpoweramp software for free at: http://www.dbpoweramp.com
I use it all the time for converting FLAC and SHN files to WAVE.
It's really simple to use and will convert it to a wave file in a matter of seconds so you can burn it onto a cd.
08-29-2007, 10:51 AM
whatever program you use to burn, I'm sure it has an "audio" option. If so just drag your mp3's on it and burn. 99.999% of all burning apps will convert the mp3s for you during the cd burning process. Their is no need for you to do anything else.
If you want to burn mp3's on a cd while keeping them mp3, then just burn it as a data disc. very simple
08-29-2007, 03:57 PM
I use Nero 6 and make an Audio CD. Just drag the MP3's the audio timeline.
08-30-2007, 06:11 AM
You could just use Windows Media Player if you want an easy method (yet unbelievably slow at times). Just go to the burn feature and drag the MP3's into the burn list (this is with Media Player 11.....I can't remember if its any different in previous versions).
My Transformers Website - http://www.tfrid.com
08-30-2007, 09:32 AM
Use Nero. Its easy. Just select 'Make Audio CD', Then drag and drop the mp3 files into the window, then press 'Burn'. (Oh, and make sure you have a blank cd in your cd writer).
