02-16-2011, 07:13 PM
w3tno w3tno is offline
On occasion I have the need to capture and record audio and video which appears on web pages. YouTube videos are an example, but basically if it appears on my screen I want the ability to capture and record it.
I have just received an email from Total Recorder for their product which purports to do what I have described above. They are charging $54 for this product.
Does anyone have any experience with this product or any comments or advice?
02-17-2011, 03:43 PM
I've never heard of it.
For at last 3 years now, however, I've used the payware Replay Media Catcher with great success.
Applian, the maker of RMC, has proven themselves to be a leader in this area, and their software is well known and well respected.
You can buy it for $39.95 from them directly at: http://applian.com/download-videos
In the few instances that it fails (very rare), I'm able to use the freeware URL Snooper, to sniff out the URL and manually download the video.
See http://www.donationcoder.com/Software/Mouser/urlsnooper
For Hulu downloading, you'll need to use the dedicated freeware Stream Transport, which is also able to capture videos from some sites. It's not as reliable as RMC, outside for Hulu. See http://www.streamtransport.com
For Youtube downloading, and some of those other "viral video" type sites, I find it easiest to just use the free KeepVid service which gives you a download link to save the video. See http://www.keepvid.com
Between these few tools, I'm never left unable to download clips.
I'll contact the maker of Total Recorder, High Criteria, and see if they want to submit a full copy for our review. (We don't review trial copies -- there's really no point in that.)
The following users thank admin for this useful post: w3tno (02-17-2011)
02-17-2011, 04:15 PM
I appreciate the helpful and knowledgeable reply.
audio, screenscraper, video
SignVideo PA100 (PAL version) wanted astro Marketplace 1 10-18-2010 05:11 AM
Wanted Fonts: Help identify fonts for DVD case artwork MuppetDanny Author, Make Menus, Slideshows, Burn 6 01-30-2008 05:23 AM
Toshiba (DRW2) DVD Recorder * Good or Bad Recorder Pepeart Capture, Record, Transfer 4 09-20-2006 03:12 AM
Wanted: settings for mainconcept for AP wigam Encode, Convert for discs 4 09-05-2005 04:55 AM
