03-20-2013, 05:14 PM
Sossity Sossity is offline
I was reading a thread about someone backing up a large amount of data, and someone suggested LTO tape for archinving their data. I have come across a reference to LTO tape before, and read that it is used by movie studios so it is not likely to become obsolete too soon.
I discussed backing up my data here, & it was suggested to me to use sets of hard drives; one set at home, & one offsite, & rotating them every 6 months, as I update/get new data.
should I consider LTO tape? I looked at the tapes, and see they need a special super expensive drive to read them.
or would I be better off with just hard drives?
03-25-2013, 01:24 PM
kaliree kaliree is offline
How much storage do you need? LTO drives are often very expensive ($1,000 plus range).
For the vast majority of people hard drives are probably a better option. Hard drives are almost as inexpensive as they have ever been and you can get up to 4TB of storage for a around $130 if you watch the sales. Plus you can then use those drives with virtually any system from the last 6 years.
On the other hand, LTO drives can save you money if you are storing petabytes of data and you primarily need to archive it (like a studio or bank would need to do for example).
03-28-2013, 09:02 PM
JMP's Avatar
JMP JMP is offline
Former Site Staff | Computers
The real difference comes down to the cost. A LTO Ultrium-5 tape has 1.5TB (3TB Compressed) of space at a cost of 48-50$. The highest capacity LTO tape is a LTO Ultrium-6 which is 2.5TB (6.25 Compressed), but I have yet to find a online retailer that carries them. A LTO-5 Tape Drive cost upwards of $1500. On top of that, you would need to get a SAS Controller Card as well for your computer and those range from 70-200$.
With an external hard drive as your backup/archival medium, it can cost between 150-300$ depending on the size drive you get and the quantity. We recommend 2, one for on-site and one for off-site. An external hard drive, will also be faster in terms of data access as well.
Keep in mind that any computer you want to use to access a tape backup with, has to have a tape drive, and the right kind. An external hard drive can be accessed from nearly any computer.
-JMP
- Check out my latest Editorial.
Hacking ATI MMC 8.7 to work on 128PRO admin Capture, Record, Transfer 26 07-21-2014 06:22 AM
How to copy DV tape to new DV tape with audio removed? via Email or PM Edit Video, Audio 1 09-13-2012 05:55 PM
How to get work as a graphic designer. fzgfaq Web Development, Design 4 11-18-2010 04:38 AM
VHS tape malfunction, mechanism not rolling tape properly admin Capture, Record, Transfer 0 10-12-2009 10:57 PM
Who is lordsmurf and who does he work for? lordsmurf General Discussion 0 01-24-2004 12:18 AM
