08-29-2005, 02:51 AM
tobal2 tobal2 is offline
Send a message via Yahoo to tobal2
Beginning last night, I started getting voltage errors on my Pioneer 107 burner. It only happens on writing; reads are OK.
It's happened twice on Nero 6 and once with Decrypter. After rebooting, I didn't have the problem with Decrypter again (haven't burned anything today though).
Burner going bad? Or other possibilities?
HP Vectra P3 1ghz
384MB RAM
Win XP Home
Drive is primary on IDE2
No other noticeable system errors/issues...
Been using it for a while now so it might just be wearing out
08-29-2005, 12:32 PM
Check the wiring?
08-29-2005, 12:46 PM
Everything appears to be connected tightly.
On a chance, I unplugged the PC from my UPS and moved it to a surge strip... 2 burns so far with no problems.
08-29-2005, 02:52 PM
Tcel93 Tcel93 is offline
If it begins happening again, I would suggest moving the burner to a new system just to rule out the power supply on the computer. If it happens again on the next PC, than you know your probably dealing with a burner issue itself.
08-29-2005, 03:32 PM
Switch power out the power cables if you are using a splitter.
Also exchange IDE cables.
More things to try.
Errors on the edges of converted VHS tapes? admin Capture, Record, Transfer 1 04-20-2012 01:24 AM
Pioneer dvd burner ? d.smyth Blank Media 1 04-27-2006 06:28 AM
Audio video sync errors 777sp2 Capture, Record, Transfer 9 11-18-2005 03:33 PM
Virtual Memory errors when authoring tobal2 Computers 3 08-16-2005 12:52 PM
DVD Burning Errors, Cyclic Redundancy Check and burning freezes rmehta2 Copy DVDs, Duplicate, Replicate 7 07-13-2005 12:34 PM
