11-14-2018, 10:56 PM
Sergei316 Sergei316 is offline
Hello!
Need some troubleshooting help.
Im setting up my XP-32 AGP capture system:
Intel D875PBX MB
Pentium 4 3.2 - SL6WG
Gskill DDR400 & Dell DDR400 - 2 - 1gb sticks (Installed A1 & B1 slot)
Ati Rage pro 128 AGP 4x (Not for capture... Just for Setup)
Keyboard - PS/2 to USB installed in Purple PS/2 port
SSD - MX500 formatted on Win 7 Pro (Proper Alignment for XP-32bit install)
Issues:
NO VIDEO... Using a known working card from Mac G4 (ATI Rage 128 pro AGP 4x). No beeps or any other error codes heard. I dont want to plug the AGP capture card until I can visually POST. Keyboard lit on NUMLOCK is seen. CTRL-ALT-DLT works (I think... NUMLOCK goes out then comes back on).
Do I need to get a PCI video card? Any other suggestions?
Thanks.
What I have tried...
A. Corsair CX650 PSU - 1 gb DDR400 Dell Ram - ATI Rage Pro AGP 4x - SATA0 MX500
--> Started... No Beeps... NO VIDEO... CPU Fan Running... Aux Fan Running... Keyboard CAPS/SCROLL/NUM are ON...
CTRL/ALT/DEL restarts (Lights out on keyboard and come back on)
B. Corsair CX650 PSU - NO RAM - ATI Rage Pro AGP 4x - SATA0 MX500
--> Started... 3 LONG Beeps... NO VIDEO... CPU Fan Running... Aux Fan Running... Keyboard CAPS/SCROLL/NUM are ON...
C. Dell 240 watt PSU - 2 gb DDR400 Dell Ram (A1+B1) - ATI Rage Pro AGP 4x - SATA0 MX500
D. Dell 240 watt PSU - 2 gb DDR400 Dell Ram (A2+B2) - ATI Rage Pro AGP 4x - SATA0 MX500
E. Dell 240 watt PSU - NO RAM - ATI Rage Pro AGP 4x - SATA0 MX500
--> Started... 3 LONG BEEPS... NO VIDEO... CPU Fan Running... Aux Fan Running... Keyboard CAPS/SCROLL/NUM are ON...
Im thinking video card..?
11-15-2018, 07:51 AM
The Macintosh version of the card won't work. It has the wrong ROM on it to work in PCs.
11-15-2018, 08:11 AM
I forgot all about the ROM. Thanks for your help.
11-15-2018, 07:25 PM
What will be the eventual capture card?
11-17-2018, 11:46 PM
AIW 9700 Pro. I also have a AIW 600 pro PCIe for Win 7 pro setup. Hopefully this goes a little smoother. I had to get a VGA card to test everything before final installation.
I have a full install cd of XP Home SP2. Should I pick a Pro version or would XP Home be OK?
Correction: This is going to be another XP SP2 system with PCIe AIW capture card.
The Win 7 Pro setup is for my firewire capture system. I tested this the other night on about 6 hours of video and had zero dropped frames with WinDV. I wanted to test my Sony TRV-320 camcorder because I was having issues with the PLAY / FF / REW / STOP buttons on the top panel not responding correctly after several hours of use. It seemed ok for about 3 hours than started to act up again. However, if I use the remote I had no issues.
VGA card installed. BIOS updated.
Installed XP Home SP2 on SSD.
Now I am getting an error "ERROR LOADING OPERATING SYSTEM".
Any ideas?
11-18-2018, 12:23 AM
What graphics card are you using now?
Bad OS installer disc? I've seen that before. Is it original, or did you slipstream it? Easy to do bad slipstream.
11-18-2018, 12:26 AM
Just a VGA card for breadboarding. i dont want to install the AIW until I have XP operational.
It is an original XP SP2 Home edition CD.
I have another disc. Maybe a new install.
Should I reformat in Win 7? Or from the XP disc?
11-18-2018, 03:07 AM
UPDATE 0400:
Tried several HD's, both IDE and SSD, and was still receiving errors.
The problem was the AHCI drivers not loading. I could have slipstreamed them in but decided against it.
Used IDE Seagate 80gb HD and IDE DVD player. XP loaded and running.
For sale: Complete workflow = JVC S-VHS + TBC + capture card! lordsmurf Marketplace 50 03-14-2024 11:49 AM
For sale: Complete workflow = JVC S-VHS + ES15/DVK TBC + capture card! [SOLD lordsmurf Marketplace 1 11-20-2018 09:24 PM
Best ATI capture card to use in my workflow? Caputnoodle Capture, Record, Transfer 3 09-13-2018 02:38 AM
Starting From Scratch, Putting System Together for Video Conversion rocko Project Planning, Workflows 23 07-23-2011 11:34 PM
DV Capture for MPEG1 - best system and workflow ? cyanon Capture, Record, Transfer 4 09-15-2006 10:31 AM
