-   Computers (https://www.digitalfaq.com/forum/computers/)
-   -   Microsoft works (https://www.digitalfaq.com/forum/computers/925-microsoft-works.html)
Pepeart 09-12-2006 10:31 AM
Microsoft works
I am using Microsoft word Processor and I cant find a way to alphabetize my list. Is there a way to do it? I used Corel before and it had the option
emokid 09-12-2006 11:51 AM
Microsuck Word.. yes, go to: Table>Sort ;)
Pepeart 09-12-2006 02:08 PM
nothing
here is the list
insert table
insert row
inset column
clear cells
select cell
select row
select column
select table
table format
cell height and width
cel text alignment
lordsmurf 09-12-2006 08:39 PM
I don't know that Word can sort lists. It's a word processing program. Access and Excel have sort functions, however. So does Works.
manthing 09-12-2006 09:14 PM
err pepeart, when you say alphabetize do you mean sort? or to get capitalised words?
to sort, goto table menu, then select menu sort. but this will sort each line or paragraph rather than each word.
if you want capitalised words, the select format menu, then change case menu and you'll have 5 options there.
hope this helps.
emokid 09-13-2006 12:24 AM
Whut I have....
http://s5.photobucket.com/albums/y16...rrent=word.jpg
Pepeart 09-13-2006 03:28 AM
Manthing I want my list in alphabetical order
Onlyemokid I dont have sort option
I dont think my version can do it
emokid 09-13-2006 04:29 AM
Hmmm. Odd, sorry, thats the only program I really know that can alphabetize. Because before I got it, thats the only reason I really needed it.
emokid 09-13-2006 04:32 AM
oh yeah, give me your list and I'll alphatetize it for you, and send it back LoL (if you want it done quickly and whutever ;) )
Pepeart 09-13-2006 01:56 PM
it was my game list. I just finished.
