11-07-2006, 03:37 PM
stoogedog stoogedog is offline
hi, awhile back i posted about having problems with my computers sound card after having to reboot xp. never got it back working. while doing a web search the other day i came across a siig usb sound card. from reading about these, i thought this would work so i purchased one. does anyone here know if this will work just like an internal sound card. any input or info will be appreciated. thanks stoogedog
11-08-2006, 08:07 AM
markatisu markatisu is offline
it should work just fine, its going to be no different then say a usb network adapter or a usb burner.
If you are planning on doing hardcare gaming or something like that it may or may not work but I dont see why it would not work as a replacement for a sound card, sound cards dont do a whole lot of processing anyway
11-14-2006, 02:16 PM
hi, got in a siig usb soundwave 7.1 sound card today and it corrected my sound problem on my computer without having to open it and taking the internal sound card out. i now have sound. thanks samuel
Sound Problems during Capture Tom_n_Jonna Capture, Record, Transfer 2 02-01-2007 09:14 PM
No sound with MP2 capture, ATI MMC problems progressor Capture, Record, Transfer 7 07-15-2005 10:07 AM
Sound Card / Digital Audio Cables CaZeek Capture, Record, Transfer 3 12-13-2004 10:58 AM
? about sound card and ATI purple box jrnyhead Capture, Record, Transfer 1 07-11-2004 07:58 AM
Help with ATI sound: audio is noticeably lower volume in capture buckcrisp Capture, Record, Transfer 4 05-04-2004 01:47 AM
