Go Back   Forum > Featured > Coupons & Deals > Web Hosting
03-16-2013, 05:27 AM
Right now, you can get 60% off your billing at DowntownHost.com
Simply use wht2013 as your coupon code, and watch your price drop!
This means that if you chose a $15.95 per month plan, you’ll only pay $6.38 a month! The bigger plan you select, the bigger your savings will be. You won’t find a price this low with so many features and services anywhere else, especially when you consider the fact that you can get it for 60% cheaper.
