Go Back    Forum > Digital Life > Digital Devices
09-28-2015, 04:33 AM
tarun_bazooka tarun_bazooka is offline
hi all i am interested to buy Asus Eeebook X205ta Notebook from "here"
Is this notebook good for dailt use lie blogging, internet surfing and normal use?
And the price mentioned above is good?
09-28-2015, 04:56 AM
15490 rupees is about $235 USD.
Somebody here just finished getting a Nextbook tablet from Walmart for $227 + tax, and it's fine:
http://www.walmart.com/ip/44503406?w...093952&veh=sem
The specs on it are about the same as yours.
That exact Asus is on Amazon for $199, but by the time you add state tax, you'd be looking at about $210.
Those used to be called "netbooks". They're not really full laptops. They're only good for light work, like using the web, a few office documents, and some games. The normal consumer stuff.
09-28-2015, 05:04 AM
thanks i appreciate your reply but i live in India and i think if o order this notebook from walmart or Amazon.COM it will be more costlier for me.
I need it for normal use only(internet surfing, music,movies etc) ANd is this good for these works? or just normal?
09-28-2015, 05:37 AM
I know that.
My point was that $215-235 is the typical price range for that sort of netbook/notebook. You're not going to find it much cheaper.
That new Nextbook has 64gb instead of just 32gb, but everything else is the same. I'm not sure about what's available in India. At very best, you could maybe find a 64gb model at that price. But then again, maybe not. And it might not matter than much, depending on your usage.
Asus has always been a good brand, so you're probably looking at a good one. The reviews for it have all been pretty decent.
There's a detailed review for this model on Youtube:
09-28-2015, 05:51 AM
wow thats cool thanks bro
asus notebook, computer, deal, laptop, price
Will my LCD monitor be good enough for video work? (Asus VH242H) rappy Project Planning, Workflows 1 04-24-2012 01:11 PM
How to disable daily 'Plesk Scheduler notification' server emails kpmedia Web Hosting 2 12-19-2011 07:29 AM
Micro 4/3rds cameras by Panasonic as good as Nikon DSLR's? As good as D7000? Sossity Photo Cameras: Buying & Shooting 1 10-28-2010 10:47 PM
