Quantcast Shrinking a DVD with DVDShrink - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Copy DVDs, Duplicate, Replicate
12-06-2009, 10:11 PM
Superstar Superstar is offline
How do I shrink a video with DVDShrink? I just made a DVD and it was like 14 MB too big to burn to the blank dvd, and I dont want to re-capture and re-encode, that will take a total of over 13 hrs..so, what do I do to make it fit?
12-06-2009, 10:25 PM
Or, is there anyway to shrink the AC3 audio file? DVDShrink says its 511 mb
12-07-2009, 10:55 AM
DVD Shrink is made to "shrink" commercial release DVDs by reducing the overhead often found on studio-made discs. The fast re-quantization/transcode method used for this process is fairly abusive, but since it's primarily reducing overhead alone, it's fine.
Some commercial DVDs, specifically well-packed TV show releases, cannot be shrunk without looking really crappy afterwards. There is no overhead.
The same is true of homemade DVDs, from your own captures. You have no overhead. All of your bits are needed on that disc. Using DVD Shrink on a homemade disc is very abusive, and the quality torpedos quickly. Very often you're left with blocky video full of noise. DO NOT USE DVD SHRINK ON HOME-RECORDED CONTENT.
You can reduce the size of the AC3 to a lower bitrate. Standard choices are 192, 224, 256, 384, and 448k. Just try to move down one setting from what you're using now. You may take a quality hit from this, but it really depends on the quality of the source audio. This can be done in any AC3 encoder, and we've discussed them here before on the forum. For example, see http://www.digitalfaq.com/forum/show...-ac3-1465.html
__________________
If this site has been as helpful as a book or magazine, then donate a few dollars or consider upgrading your membership.
You must be logged in to view images and download attachments.
12-07-2009, 11:16 AM
I do use TMPEG Sound Player to make them AC3, I've been using 384, but I'll try to drop it down to 256 and give that a shot.
DVDShrink... loosing its touch? Neuroslicer Copy DVDs, Duplicate, Replicate 4 02-20-2006 05:19 AM
DVDShrink destroys home made dvd? manthing Copy DVDs, Duplicate, Replicate 2 01-27-2006 02:20 AM
All times are GMT -5. The time now is 11:56 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
