Originally Posted by nick_27
I recently bought a Pioneer DVR-X162Q DVD burner.
Excellent DVD burner. Good choice.
You were right...I shouldn't have installed the software (Roxio Venue Suite) that it came with. In short: it didn't work.
Roxio = crapware. They try to do too much, and as a consequence, end up doing terribly at all of it. Those "our program can do everything" apps are generally pretty dismal, as you have to take shortcuts to integrate what are usually unrelated processes. Multitasking is a myth, even when the computer is the one doing the work. You do one task well, or several tasks concurrently and NOT so well. Period, the end.
Is burning software still available somewhere on this site?
Read this:
How to Replace Nero / Roxio with Freeware ----
http://www.digitalFAQ.com/forum/show...nero-2070.html
You seem to have copied a link in short form -- not the "..." in the middle.
It's been broken somehow, somewhere. I'd fix it, if I knew where it was, assuming it's on this site somewhere.
Thanks much for a great site.
And thanks for your feedback.
Originally Posted by _K__
Indeed it is. And you'll find it on the above linked thread. However, Imgburn has some weakness (easy CD audio burning, for example) and areas where other programs are needed.
Check out that full list:
http://www.digitalFAQ.com/forum/show...html#post11011
I'm
Nero-free and Roxio-free, and plan to stay that way.
