-   Copy DVDs, Duplicate, Replicate (https://www.digitalfaq.com/forum/dvd-copy/)
-   -   ImgBurn problem with missing files (https://www.digitalfaq.com/forum/dvd-copy/4264-imgburn-problem-missing.html)
Superstar 06-12-2012 10:34 PM
For some reason, everytime I try to copy a DVD in ImgBurn, it's not working. When I open up the folder, location where the DVD files are saved, nothing is in there, however when I go to that folder, all of the DVD files show up then....but they're not showing up inside ImgBurn.
How do I fix this?
Steve(MS) 06-14-2012 11:23 AM
Not sure if anyone understands what you want. What are you trying to do, burn file to disc?
If so try this, open up a small window where the file is located (outside imgburn).
Then have imgburn opened say on the right side of small window. Then drag and drop file in imgburn window.
lordsmurf 06-16-2012 03:11 PM
As in copy directly from one DVD onto another, using ImgBurn? If so, then that's a bad method.
Use something else --- or read ISO in ImgBurn (save to hard drive), then write ISO (from hard drive to new disc).
