Is TMPGEnc the go-to DVD authoring/burning software?
Iv'e seen this software mentioned a lot in The DFAQ GUIDES,so with money being tight,I was wondering if I should go ahead and purchase TMPEGenc, But there are about 3 different versions on the Pegasus Site to choose from???:unsure::beer::drunk:
PLEASE REPLY TO 11/10/12 question
Is TMPEGenc the go to DVD Burning Software????:unsure:
AVStoDVD is free. I've being using it, not to hard to learn, seems to work fine, good tutorial and help fourm, author very responsive to questions.
Dad2 http://www.videohelp.com/tools/AVStoDVD http://forum.videohelp.com/threads/2...upport-Thread? http://adubvideo.net/how-to/convert-bluray-dvd-avstodvd |
DVD 'Burning' software? On this site, mainly ImgBurn is highly suggested for 'burning' DVD's.
Regards |
TMPGEnc Authoring Works is one of the suggested authoring programs, yes -- but not always.
For purely "burning" a disc, use ImgBurn. So what is it that you're wanting to do? :question: |
In reply to Lordsmurf's question: Just make a copy of captured MPEG2-DVD file to..(1) Test ATI Card for reverse Interlace on my system b4 going hog-wild,and (2) to send DVD copies of captured video to friends and family.( Iv'e spent a very long time on this subject,and am getting some good results finally,and many thanks to this site by the way!!!:)
Simple DVD Creator is a freeware program that will allow you to author menuless discs which I think will serve your purpose just fine. It has been discussed in length here on the forums and is what kpmedia recommends for you. (He is across the room from me currently.) If you are wanting to create full menued discs, then TMPGEnc Authoring Works will do the job for you.
-JMP
Thanks, and no problem. I have been busy FLUSTRATING with my Audio computer/music stuff for winter anyway,but your reply helps!.....Awhile ago I tried a few different links and mirrors to download ImgBurn, and was warned or blocked by my ESET nod32 antivirus that a possible threat existed (Toolbars?) and gave up.(ESET HYPERSENSITIVE?) Can I buy ImgBurn somewhere?...Also looking for Audio file converter, and also CD burning software.:question:
Answered/continued here: http://www.digitalfaq.com/forum/dvd-...n-despite.html
Thanks. |
