Errors trying to copy a DVD?
I'm trying to copy a DVD in ImgBurn by making an image file, and everytime it gets down to about 40 seconds left, all these errors appear in the log, and it fails. I also tried ripping it with decrypter, but the same thing happened.
Is there any other options that I have? |
i use DVDfab for copying
This probably isn't related to the copy/ripping software. It sounds like bad media is the culprit.
What's the media ID? Try another drive. What drive are you using now? If using Imgburn, I assume this is a homemade DVD of some kind? ie, DVD-R or DVD+R Have you tried to copy the last file with just plain ol' Windows Explorer yet? It's NOT good to do, but sometimes that works best. |
I also tried with DVD Shrink and during the analyzing stage, it got down to 3 seconds when it stopped working.
how do I check the media ID? It's a Verbatim disc The drive I used was my portable DVD burner Yes, it's a homemade DVD-R No, I don't know how to copy the last file with Windows Explorer... |
Any other suggestions for this?
Windows Explorer - "My Computer" = drag and drop to copy
It may be a bad disc, or the drive has issues reading that particular disc. Try another drive. |
That didn't work either. Does that basically mean it's a bad disc & can't be copied?
Is there any other options at all that I can try? |
