Quantcast DVD burner going bad???? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Copy DVDs, Duplicate, Replicate
07-19-2006, 01:41 PM
MagnificentMarcus MagnificentMarcus is offline
How can you tell if you're DVD burner is starting to go bad?? I've been having some readibility problems when verifying with DVD Decryptor. The discs are Yuden 8X +Rs so that can't be the problem.
07-19-2006, 02:14 PM
cp32 cp32 is offline
Is your rom reading dsc okay? Have you burned something else . That dont require Decrypter?
If you can copy. It's okay. If it reads not write. Replace it.
When a liteon r-/R+ burner starts to go. You can only burn R- not R+
Not long after . It will read only.
Try lowering your burning speed to 4 X or 2x see what happens.
07-19-2006, 03:49 PM
angelofanimes angelofanimes is offline
Ehh...probably gotten too much dust? Mine had that once...
__________________
-AOA
07-19-2006, 04:47 PM
Isn't it about time you got me some new beads lmao!
Where have you been young man huh? Out prophiting from my hit record lol
07-19-2006, 08:17 PM
It may just be dirty. Consider taking it out, opening it up, and blowing out dust. If that doesn't help, open it up again, get out some isopropyl alcohol (from the drug store, 75 cents a bottle), get a cotton swab (q-tip), and get alcohol on it. Swipe the lens once, then twice, gentle but firm. Then get a dry q-tip and swipe it once to dry.
Absolutely DO NOT use a "cleaning disc" of some kind.
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
07-20-2006, 12:39 AM
Ooops, I've been using cleaning discs for a long time. This is an external DVD burner (Toshiba) and you really can't open it up. It's been a good DVD burner, I've probably burned 2000+ DVDs with it. Any recommendations on what to buy this time???? I think it is gone.
07-20-2006, 12:56 AM
Pioneer
Maybe an LG, see if Best Buy has any on clearance
But I would still suggest the Pioneer.
I assume you want an external.
I prefer firewire over USB2, given the choice.
For an internal drive, Pioneer and nothing else.
__________________
07-20-2006, 03:51 AM
Yeah, I think it is dead. It won't recognize the disc to either read or write.
07-22-2006, 05:21 PM
Well guys, I went to Best Buy and pick up a Pioneer 16X DL External burner for a total of $115.00. It works great, but I don't care for the shell that much. Just out of curiousity I checked E-bay. I bid and got the same thing today $40.00-shipped. Can you believe that price and in a heavy duty shell!
Guess what is going back to Best Buy this week?
08-09-2006, 06:41 AM
Pioneer sucks! This is the third time I've messed with these burners and everytime there is a problem. I'm going back to my Toshiba. Toshiba will read at 12.1X 95% of the time. Pioneer (made in China) are slow, shabbly built and not worth the effort.
By the way my Pioneer external is the same as the internals you guys use.
08-09-2006, 08:43 AM
I buy Liteons. Finally had to break down and get new one 16x is also a lightscribe burner too.
www.directron.com
on sale right now 39.99
I knew I should have waited
Oh well, 42.99 + ground 52.54 still cheaper than in stores
It only takes 5 days to arrive for ground.
http://www.directron.com/shm165h6s.html
Last one lasted 3 yrs . Not one problem.
The downside for me. I can only burn disc. cant lightsribe due to outdated processor . I m waaaaaaaaay under system requirements
Requires 1.3 mine 950
How do I know you ask? I put the burner in my neighbors 1.9 pc . My lightscribe worked fine
08-09-2006, 09:59 AM
If you want a good reader drive, get a BTC.
If you want a good burner drive, get a Pioneer.
__________________
08-09-2006, 11:46 AM
Sorry guys, the Toshiba 5372 is one of the best I've used. Funny thing about them, is they are nearly twice the price of the rest. Cheapest one I could find is $75.00.
08-09-2006, 11:47 AM
MEN.
08-09-2006, 05:07 PM
Yeah, we invent everything but a mute button for women!
DVD Burner jrnyhead Blank Media 3 01-17-2009 03:21 PM
New DVD burner issues naga Copy DVDs, Duplicate, Replicate 4 06-26-2008 02:33 PM
DVD Burner problems MagnificentMarcus Blank Media 4 07-20-2007 06:43 PM
Lite-On 16x DVD burner Cajunasian25 Blank Media 2 12-09-2006 09:35 AM
Dvd burner help d.smyth Blank Media 3 02-15-2006 05:33 PM
All times are GMT -5. The time now is 08:12 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
