Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
12-10-2007, 03:38 PM
NOTE: The same method can be used to screen cap sets. Remember to crop off the overscan, about the outer 7% of the image, when showing your screen cap or menu image.
Please remember to view the menu bleed guide. Yes, bleed, a design term. See http://www.digitalfaq.com/forum/show...ained-512.html for more information.
This guide you how to take screen caps from images, to use as needed. my recent Dukes menu, for example, was partially made with a screen cap. I screen capped a scene in the intro, and then cut out the General Lee (and doctored it some).
A straight screen cap should NEVER EVER be used as the whole menu. It's just a good way to get elements, or parts of the images that create a menu image. Screencap-only menus look like crap. Combine it with the elements of design to make something nice.
PowerDVD and most other programs that can take screen images distort the still with their own processing and filters, usually making it blurry. That's not what we want. We want the raw video still, unprocessed.
Anyway, this is the way to do it:
Open your MPEG file in VirtualDub. If you need a good copy of VirtualDub, get this one:
Unzip and stick in C:\Program Files\VirtualDub
Go to the video menu and copy the source frame.
You want to get an iamge with ZERO interlace showing. This is bad. It will make the screen go absolutely bonkers trying to display it. And it looks bad, even if the screen was fine.
Get yourself a good image that does not show interlacing. Go frame by frame until you find one.
Go to Image - Size and resize to 720x540, a true 4:3 resolution supported by most all authorware.
Don't use anything else. Not 720x480, not 640x480, those are wrong.
Crop out the overscan and other crap you don't need. You never want noise on the menu. In fact, you may only use part of the screen cap, not the whole thing.
The three "city" images on the bottom of my CSI Miami menu are screen caps:
also the Pokemon Adv. Battle set (group on right side), design elements to the left
and Shark S1 (entire frame), overlay added, partially transparent (design elements)
the aforementioned General Lee cut-out from screen cap, everything else is from other images or design elements created in Photoshop
Once you get the capture the way you want them, it needs to be understood that video interprets color different than still images operate it. So we need to tweak the color and contrast a bit, using the LEVELS in Photoshop. The bars in the middle represent shadows, midtones and highlights. Generally, you drag the shadows right (in), the midtones where needed, and the highlights left (in) until the image has a good exposure. The DVD menu will be re-compressed to video colorspace by the authoring software. We want to avoid double processing (original video levels processed again), hence the corrections beforehand.
Those with more advanced Photoshop skills would doctor the image, with cloning, painting, filters, etc.
...... and that about does it. Use the menu template I created.
12-10-2007, 03:39 PM
As a side note, the Boss Hogg image would suck for a menu. I just randomly grabbed an image real quick, to show how it's done.
VirtualDub - frames inserted? lookouts Capture, Record, Transfer 3 10-15-2006 09:28 AM
Using VirtualDub for editing MPEG video admin Edit Video, Audio 0 11-16-2005 04:20 AM
Purple band on AIW TV and Captures Jerome Capture, Record, Transfer 12 04-30-2005 09:06 AM
9600 AIW captures excellent, but authorware wants to reencode ? -d00d- Capture, Record, Transfer 4 06-12-2004 01:58 PM
Convert 16:9 to full screen jrnyhead Encode, Convert for discs 1 05-19-2004 12:07 PM
