02-17-2008, 06:20 AM
I want to make a few menus in widescreen. Can someone make a psd file for widescreen menus?
thanks
02-17-2008, 08:50 AM
Is the content widescreen too? They need to match, You can't mix.
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
02-17-2008, 09:03 AM
of course.
i found something to use on photoshop cs3 for now but an actual overscan psd would be better
02-18-2008, 02:11 AM
I hated Cs3 I m back to CS2 lol . Cs3 has a widescreen template. Select the option to view Guide.
Or open your DWS Template > Select ratio to be widescreen ...Piece o pie.
06-14-2009, 06:05 PM
Wait a second -- are you guys saying you can't have 16:9 menus with 4:3 footage? I've done this without any problems with DVD-Lab Pro.
06-15-2009, 04:13 AM
Some software disallows mixing. From both a tech stance, and a content stances, it's best to match anyway.
I could never understand why certain DVD releases, (NCIS season 3 was one, I believe), where the menu was 4:3, but the content was 16:9. On some televisions, this was a nuisance, causing the viewer to have to switch the TV from 16:9 to 4:3 modes. What was the point of the different-sized menu?
06-15-2009, 07:25 AM
Ah ok I see where you are coming from. Yeah, I've noticed some DVDs like that too -- usually older movies where the print is 4:3 but the menus are 16:9 for some reason. I guess that depending how someones DVD player is connected and setup that it might not properly switch between the two. I have my DVD player set to 16:9 auto so that it plays 4:3 stuff in the proper aspect and then switches to 16:9 when necessary, but some people prefer 4:3 stuff to be stretched. I think you can also use in DVD Lab Pro to force a letterbox of the 16:9 menus on a 4:3 display.
| Thread |
How to make a DVD montage
mehrdad |
Encode, Convert |
20 |
06-27-2008 09:30 AM |
How NOT to make a menu
markatisu |
5 |
09-03-2007 03:28 PM |
How to make bad DVD copies
lordsmurf |
Copy DVDs, Duplicate, Replicate |
1 |
01-04-2006 11:58 AM |
Opinion of recording in Widescreen mode?
padre2 |
1 |
10-18-2005 10:43 AM |
The OVERSCAN Issue Explained (for DVD Menus)
lordsmurf |
9 |
07-16-2005 05:15 AM |
