TMPGEnc DVD Author 3 steals HD space
Hi all, been a while just kinda been out of the whole video thing for a while and just kinda got back into it.
I had to get back in the groove of things, I forgot how to use some of my favorite software...including TMPGEnc DVD Author...I am currently using ver. 3 If you use this software, be aware if you find that your hard drive space is disappearing it may well be this program. Especially if you import DVD files to re-author your own discs. To find out, check the following file: C:\Documents and Settings\"user name"\My Documents\TMPGEnc DVD Author 3\dvd import it seems that the program imports the dvd information but does not delete it automatically. I recovered 120GB of space by deleting the temp files that reside in this folder and it has been months since I used it last. I noticed that my HDD space was getting smaller and smaller even after I had cleaned the drive, uninstalled a bunch of games and got rid of useless programs then I stumbled upon this and now I got back more than half my drive. |
Good find.
I had a similar issue recently, a piece of software dumping large temp and log files in the My Document subfolders. CCleaner can help you some too, it will remove junk files it finds. |
You can set TDA 3.0 to dump those files into another directory - I do mine into \temp, so I can just purge them with my other programs litter.
