08-10-2011, 04:18 PM
Sorry I'm bringing an old post back to life, but I have a question. I haven't made a DVD in quite awhile, and I can't remember exactly what I'm supposed to click on the finish tab.
I know the video says to click the "Create DVD Folders" box, but I keep thinking that I'm supposed to click the "Create disc image" box.....
Just to clarify, do I click the "Create DVD Folder" box, or the "Create disc image" box?
Then, in IMGBURN, do I go to Mode -> Build, OR Mode-> Write?
08-11-2011, 02:17 AM
Trying to go from memory....
I think this forum recommends create DVD folder, that is what I used and got good results.
For IMGburn, click the mode button on tool bar, then ez-mode picker, then "write files/folders to disc".
Admin can either verify or correct me on this but I think that should do it for you.
After you click that write files...then you can click on the right top (device) and set how many discs you want to burn
and set your write speed.
IMG should prompt with dialog boxes, just make sure it doesn't give you the too large file for disc or however it is worded.
If it gives you that warning, cancel as it will be a coaster.
This shouldn't be a problem if you have already have your files ready for whatever disc size you are using.
If this isn't enough, we'll try to walk you through it.
09-18-2011, 05:44 AM
No.
Folder.
DVDWS2 is notoriously bad about preparation of DVD-Video assets, including bad gapping and bad layer breaks.
Great authoring software, lousy built-in burning (including image creation).
Build.
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
| Thread |
How to add background music in Ulead DVD Workshop 2
Superstar |
1 |
07-28-2009 07:28 PM |
Ulead Workshop 2.0
wheezer210 |
9 |
01-13-2007 04:31 PM |
angelofanimes |
4 |
02-22-2006 03:21 PM |
Ulead Dvd Workshop 2 help?
emokid |
12 |
07-11-2005 11:52 PM |
Ulead DVD Workshop - Audio
ishmot |
1 |
05-20-2005 12:07 PM |
