I know there can be issues with burned DVDs not playing on some players, but I have experienced it now myself with some home videos we converted from VHS to DVD, following what I think are some safe steps. These DVDs do play just fine on our Sony DVD player (prob 6 yrs old now) and on all computers, but will only play on one of three DVD players that a relative of ours uses (one new Blu-Ray, two regular DVD players, maybe 5 yrs old each.. one works, the other doesn't). The discs don't load at all, just show an error of some sort. Just trying to determine if there is something I can adjust to make it better, or if it's usually an issue with the players. Here are the details:
- Using Verbatim DVD-R (4.7GB) - using the standard discs, *not* the Life Series
- Videos are about 1.5 hrs long, Mpeg2 output from
MainConcept Reference 2.1 encoded at 5K bitrate or so, the Audio is Dolby AC3 encoded
- Authoring with with DVD Studio Pro 4, using simple top menu only. (single layer, multiple region codes, a handful of chapter markers) I can give more details about the DVDSP4 settings if it would help
- Burning with a Macbook Pro (2008) superdrive
The discs come out great, as far as I can tell.. just can't play them everywhere. I don't have the details on the players right now, but am looking for some guidance on whether this is most likely a DVDSP4 issue, or the burning drive I am using, which I may have some control over.
thanks!
