Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
03-23-2013, 11:00 PM
Superstar Superstar is offline
What's the best way to remove an advertisement for a website from the beginning of a homemade DVD? Would it just put it into something like Womble & just delete it that way, or would that throw off the audio sync for the rest of the DVD?
04-08-2013, 09:44 PM
Just remove it with Womble. You'd have to decompile the disc and re-author it, of course.
There several ways this could be done.
06-13-2013, 07:44 PM
When you say I'd have to decompile the DVD & re-author it, how exactly would I do both?
I don't think I've ever decompiled anything before. Do I need a certain program to do that with?
As far as re-authoring, what's the steps & programs needed to do that? The DVDs have music on the main menu, as well as chapters on them.
07-26-2014, 06:31 AM
De-compile:
DVD Decrypter IFO mode is first, which gives you VOB (audio, video, subtitles, nav data). Then demux the MPEG video and audio in one of several programs -- for example, TMPGEnc Plus 2.5
Re-author:
Use something like TMPGEnc Authoring Works, TMPGEnc DVD Author, Ulead DVD Workshop 2, or DVD Studio Pro (Mac). Import the assets (audio, video, subs, images/menu, etc).
If you want a menu similar to the last one, then it will take some effort. One way to do it is to find the menu VOB (also rip it in DVD Decrypter), open in VirtualDub, take screen caps, and then open the screen cap in Photoshop. But in most cases, I prefer to take this time to upgrade the menu to something better, Usually, when I have to fix a disc, the menu sucked too.
THIS PROCESS IS NOT EASY!
It's not for complete DVD novices.
This was an unanswered question or unresolved issue found during a site audit. It's hard to have an FAQ when the answers are missing, or final outcomes are unknown. At The Digital FAQ support forum, questions are never intentionally ignored, and may have been missed due to a forum glitch or human error. More details on the audit. (In some cases, threads have been edited/updated with newer information.)
How do I remove this noise from my capture? CyborgHyena Restore, Filter, Improve Quality 4 02-07-2013 06:05 AM
Problem on how to remove the link ECruzDigital Website and Server Troubleshooting 5 02-03-2013 01:43 PM
How to remove blurred image in video? vnmenon Edit Video, Audio 1 07-12-2012 07:13 AM
Remove DMR lock & convert cnickle1 Encode, Convert for discs 5 03-22-2009 01:11 PM
How can i remove black bar from side of mpg?? Konfusion Restore, Filter, Improve Quality 12 11-27-2007 05:04 AM
