Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
11-12-2005, 07:15 AM
MBates05 MBates05 is offline
I have a question regarding making text buttons for a menu using DVD Workshop 2. I know that you have to use photoshop to create the background and have already done that, but how do you create text buttons using the program. I orignally created the text in photoshop that I wanted to be the buttons but don't know how to link videi to it and make it a button in the program. I know that it is possible to type text when you are in DVD Workshop and then attatch video to it, but is there a way to make the text in photoshop along with the background image and then attatch video in DVD Workshop to it? All help will be much appreciated.
Matt
11-12-2005, 08:47 AM
Yes, sort of.
You have to have a still image in the background. Whether it's temporary or permanent makes no difference. You simply must have one to add a multi-layer PSD file.
Make a PSD file in Photoshop 7 or later. Make your text layers.
After you have a still image background, go to BUTTON and then in the import manager, go to the OBJECT and GENERAL OBJECT. Import your PSD file. Drop it on the desktop as a button. Each layer can be resized and linked independently. You can also resize as a whole. I would suggest, if you want to use a multi-layer PSD file, to use the background as a BMP file in DVDWS2, and not as a background layer in the PSD file. It just looks better coming from a BMP.
Sort of round-about, but works great.
11-12-2005, 10:18 AM
Thanks LS. I appreciate all the advice recently.
Matt
Menu questions - Photoshop + DVD Workshop admin Author, Make Menus, Slideshows, Burn 0 10-18-2009 12:23 AM
Ulead DVD Workshop 2 Menu Problem bigk181 Author, Make Menus, Slideshows, Burn 1 12-15-2008 09:13 AM
Help! another menu question... manthing Author, Make Menus, Slideshows, Burn 2 04-09-2006 09:22 PM
Dvd menu question darkness34r Author, Make Menus, Slideshows, Burn 7 09-24-2005 03:13 PM
? about wavy motion on video menu in dvd workshop MBates05 Author, Make Menus, Slideshows, Burn 3 06-15-2005 05:19 PM
