06-14-2006, 08:12 PM
manthing manthing is offline
okay people,
imagine i have button 1, button 2 etc on my menu.
when button 1 is clicked, it will play intro, then movie 1.
when button 2 is clicked, it will play intro, then movie 2 etc.
now what i would like to do is have an option on the menu, like a tick/check box, that controls whether the intro is played or not. checked, intro plays, unchecked, skip intro.
this is sort of like whether you want subtitles or not.
however, i'm not sure what to look for in the manual.
so, please tell me the techno-word/jargon that i'm looking for so i can look up for myself, or maybe a quick 1-2-3 how to guide?
cheers up front.
06-14-2006, 08:17 PM
You would make two menus. The "checked" menu would be identical to the first one, only have no intros specified when the buttons are set up. And then if you use a checkbox visibly on screen to show with/without intros, then your background image or motion clip would be different (one a blank box, one with a checked box).
Easy enough.
06-14-2006, 10:40 PM
ahhh i seeeee. clever little trick. tttttttaaaaaaaaaaaaaaa
JVC HM-DR10000EK PAL with NTSC enable features Mejnour Capture, Record, Transfer 3 02-05-2012 07:45 AM
Unable to enable Shell Fork Bomb Protection in cPanel ? kpmedia Web Hosting 0 01-27-2012 12:40 PM
How to disable root logins to secure SSH on Linux server (or VPS) kpmedia Web Hosting 0 01-10-2012 07:00 AM
Motorola DVR 6412: Can I enable USB? cliffsloane Videography: Cameras, TVs and Players 1 08-20-2011 09:07 PM
Using RAW + JPG option in Nikon D7000 - How to use, set? Sossity Photo Cameras: Buying & Shooting 3 06-08-2011 04:50 AM
