Sony DVD Architect crashing with DVD project
1 Attachment(s)
This is a nice Authoring tool.
Ulead tends to crash on me. Even with my new hard drive lol. So I installed this. You have the option to select your output audio as Ac3 5.1 Surround sound :D or Stero. You can layer video & psd files easily. all drag n drop. Nothing real complicated about it. Just take a little getting used to. It takes less to create a dsc . I was trying to do video in the background, a transparent LOGO in the front, without looking stretched. I was doing a DVD for my husbands band. They wanted the LOGO displaying with vid behind it. The end result was cool. Similar to LS X MEN MENU less work lol. I had an intro clip playing in the Background. While the "MISFIT TOYS" Logo Attachment 236 In the front . The only visible part was the logo ( none of the black ) , Video, Text. Like TDA & Ulead. You can select an audio track to play as background music Create a Normal menu- follow Phils Thumbnail method but... Just select the entire layer to be transparent. Keep the second layer visible. ( Show). Runs smooth on older machines lol. Easy to use. very flexible . Surround sound optional :) :D |
I've been using Vegas and DVD Architect for about 2 years now CP... love it. (used to be owned by Sonic Foundry before Sony realized it was such a great product)
