08-25-2013, 08:40 PM
Now let's learn how to use File Manager
1) Click the File Manager icon
2) Choose the directory you wish to open, then click Go
This is the File Manager interface, where you can upload files to your account, delete files, change file permissions, and a host of other functions
On the left is a collapsible list of folders in your account...
... while on the right is a list of all files and folders within the folder selected on the left
It is in the public_html folder where your website files (html pages, gif images, etc) must go
Use this function to upload files to your account, and set their permissions
Creating a new folder is easy...
... as is creating a new file
You can also use File Manager to change the permissions of files or folders
Basically, File Manager makes it easy to manage the files and folders in your account, when you don't have access to an FTP
application
This is the end of the tutorial. You now know how to use File Manager in cPanel
Install fail2ban with CSF/LFD in cPanel; sample jail.conf config file kpmedia Web Hosting 8 02-06-2014 07:22 AM
How to use webmail from within cPanel Brent Web Hosting 0 08-25-2013 08:28 PM
How to add an MX entry in cPanel Brent Web Hosting 0 08-25-2013 08:26 PM
Source file in sync - Output File completely out of sync? DeeSeven Encode, Convert for streaming 3 07-25-2013 10:58 PM
Advertising Manager plugin updated for WordPress 3.4.2+ [DOWNLOAD] kpmedia Website and Server Troubleshooting 0 09-26-2012 12:42 AM
