04-01-2012, 10:13 AM
License key has been updated to the most recent version.
Current license key number is PLSK.0123456789.1234.
Plesk automatically renews its license key every three months, and by default the server is setup to notify the admin.
You'll only see this on a VPS or dedicated server, Windows or Linux.
It's expected and normal behavior.
While you can turn it off -- don't. If there's a renewal error due to whatever reason (network connectivity being most likely), then you won't get notice of failure. And then your panel may shut down after the grace period ends! That would be a situation of making a bad situation worse.
__________________
Need a good host?
Find one here: List of the Best Web Hosts in 2012 - Shared, reseller and VPS hosting
How to disable daily 'Plesk Scheduler notification' server emails kpmedia Web Hosting 2 12-19-2011 07:29 AM
Plesk warning email error: How to fix 'The period of validity is about to expire' kpmedia Web Hosting 0 09-22-2011 09:47 PM
Plesk Linux default vhosts folder location, edit Plesk default page kpmedia Web Hosting 0 04-21-2011 11:52 PM
How to restore/migrate Plesk 8 into Plesk 9 - Windows/Linux kpmedia Web Hosting 3 10-01-2010 02:50 AM
Plesk Windows webstats/plesk-stat authentication errors kpmedia Website and Server Troubleshooting 0 10-01-2010 02:46 AM
