Quantcast Hook DVD recorder up to record from satellite? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > Home Entertainment and Videography
04-05-2010, 03:49 AM
continued from email..
IS THERE A WAY I CAN HOOK A DVD RECORDER TO THE DVR THAT THE SATALITE CO. GAVE ME SO I CAN RECORD THE MOVIES OFF IT?? THANKS
Satellites broadcast a non-video digital datastream down to your dish, and the receiver is required to translate that data into channels that you can tune to. Therefore, there is no way to bypass a digital box.
However, you output normal analog video data, through either the composite or s-video connection.
Your "satellite box" (receiver) appears to be one of the DVR units, that can also save video streams for later viewing.
To further save those videos to DVD, all you have to do is plug it into a DVD recorder, through the composite or s-video output. S-video connections are suggested, being higher quality connections than composite. Composite = "yellow wire", while s-video is the little round 4-pin connector (usually a black wire).
This is a realtime activity, meaning a 1-hour show off the DVR will take 1 hour to record on a DVD. You press record on the DVD recorder, and play on the DVR. What you see on screen is what you record.
Remember to use a good DVD recorder, and to use good blank DVDs. If you need some help picking out a good recorder and blank discs, see these guides:
Hope that helps.
Remember to post questions in the forum, we try to avoid tech questions via email.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
Using Liteon DVD recorder to re-record scratched disc? admin Capture, Record, Transfer 30 02-28-2010 09:10 PM
Can't Record From DVR to DVD Recorder rob0466 Capture, Record, Transfer 7 02-19-2009 06:52 AM
How to properly hook up VCR, TBC and DVD recorder ? mrwhitethc Restore, Filter, Improve Quality 7 02-25-2008 11:47 PM
HDTV on satellite: Signal outages due to severe weather ? Neuroslicer Home Entertainment and Videography 3 01-19-2006 07:53 AM
Correct monitor hook up during capturing 777sp2 Capture, Record, Transfer 1 09-28-2005 04:10 PM
All times are GMT -5. The time now is 09:40 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
