Originally Posted by conductor71
it says the video recording compression system on the hard drive is MPEG2 (VBR). However, I am quite sure that is not the same thing as the proprietary file system you are referring to here, otherwise you would know what it was.
MPEG-2 is the format of the video encoding.
It's completely separate from the file system, which is the format for how data is stored on the physical drive.
wondering what would happen if I used the Magic Bridge to try to connect this JVC external hard drive via the Humax USB slot-
Like the JVC, it may have a proprietary file system, too. I don't know enough about the Humax off-hand to specify one way or the other. Research would be required.
whether there is a possibility of damaging the JVC hard drive in the process,
There's always a chance of damage any time a hard drive is handled, moved between hardware, or powered up/down in any way. Chances can be slim, but the possibility is always there. And this is regardless of whether its in a computer, in a video device, etc.
and the chances of its contents being successfully detected by the Humax.
I doubt it. Sure, try it, see what happens. You never know what may happen.
I guess I am now venturing into the realms of future external back-up drives for my Humax
I'll be glad to help you spec out some drives. Just start a new thread in the
Home Entertainment and Videography subforum, and we'll give you some suggestions on reliable drives, at reasonable prices, and from which stores you should look to buy them (online, rarely brick-and-mortar).
I suppose that if I re-purchased another JVC MX10SEK, I might be able to connect my own hard drive to it and maybe it would recognise it?
This is very likely, yes.
However, I recall that it was quite a tricky procedure removing the hard drive from the old machine so it may not be something that I will actively consider doing, as there is always the possibility that I damaged the hard drive in the process of taking it out and then moving house with it
Regardless of what you do, you'll have to handle the drive, if you ever hope to recover the data. The Linux computer method would work. This could be done with a Linux boot CD/DVD, too -- you don't have to erase your Windows computers. There are also external $10 gadgets that let you turn an internal hard drive into a USB2 drive, which may help for connecting to a computer.
although it is thankfully not making any clicking sounds when I connect it to my PC.
This is good.
