Quantcast Disk don't play - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > Home Entertainment and Videography
10-18-2005, 08:53 PM
ninjastriker ninjastriker is offline
I am having a problem playing my new discs the {DV 3211} Datawrite Ricohcode (4x) DVD+R on my dvd player and my Philips dvd recorder.
Now I don't know if its my dvd RW is dying out or the discs not working and i just can't think straight at the moment to figure it out.
When i burn a straight copy of the datwrite disc from another discs, i put it in the dvd recorder and i get unknown disc. But it will play in my computer with no problems.
Its also the same when I author a dvd, the dvd just won't play and i get unknown disc or disc error.
Now with the last of my bullpaq dvd's i have to back up my data, i can sometimes get it to play on dvd recorder with no problems. But within the past few days i get the same problems as well.
About 2 weeks ago, i was able to author a disc and play the bullpaq disc with no problems. Now I get more coasters and the same with my datawrite discs.
I get maybe 1 or 2 out of 5 that plays on my dvd recorder/player. with all 5 will play on my computers dvd player with no problems.
I am getting some new discs again soon, but i need to figure the problem out first so i don't buy dud discs i can't play. I need to figure this out ASAP, to get a few sets completed.
__________________
R.I.P. Curtis Trading site 2004-2008.
10-19-2005, 04:32 AM
Sounds like the player and/or recorder is to blame?
To be honest, you mentioned so many items I'm not quite clear on what the problem is.
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
10-19-2005, 07:27 AM
-Ok i have tried it out a bit more, now a recent disc i burned on bullpaq works on my dvd recorder.
-I tried a bullpaq dvd i burned a month ago, and played it on my dvd recorder. it worked ok for a bit, but the sound/picture broke up. i then tried it again 1/2 hour later and it works.
-put in a datawrite dvd i recently copied and played it in the dvd recorder. it played for 5 seconds and then stopped and i get a "disc contains unknown data"
-tried past bullpaq on my dvd player, works with no problems. datawrite dvd-don't work, new bullpaq disc burned - don't work.
i am now burning a image with my dvd writer which is a month old and seeing if that will work. - didn't work.
- Tried all 3 discs on my portable dvd player. all of them worked.
__________________
10-19-2005, 10:27 AM
wigam wigam is offline
This sounds like one of those puzzles; a farmer has a fox, chicken and some grain, how does he get them across the river without them eating each other when the boat can only carry one at a time (Excluding farmer of course)..
Could it be the laser on your dvd recorder?
10-19-2005, 11:32 AM
Take the chicken first?
__________________
10-19-2005, 07:32 PM
I don't know what it is, hence the post. I am going to buy a new dvd player as that might be what the problem is. I just need a new one.
__________________
10-19-2005, 08:02 PM
Yep! take the chicken over first. Come back and take the fox but bring the chicken back with you, take the grain and leave the chicken. Then finally bring the chicken back over again.
10-20-2005, 02:55 AM
Tcel93 Tcel93 is offline
Can't you just tie them all up and chain them into little cages and seperate them by like 5 feet and go all at once on the yacht?
10-20-2005, 07:08 AM
well if you're gonna do that, you might as well build a bridge lol
Disk error problem kschwi Home Entertainment and Videography 5 07-19-2009 12:50 PM
Blu Ray BD-R Disk won’t Play Kent Blank Media 5 03-09-2009 11:28 PM
Best possible DVD disk that you would recommend? admin Blank Media 0 01-13-2009 04:04 AM
Thoughts on hard disk archiving ? jpklcapp Computers 3 12-07-2006 10:12 AM
Liteon 5005 and disk duplication Piyo Capture, Record, Transfer 10 11-29-2004 09:18 AM
All times are GMT -5. The time now is 04:06 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
