-   Videography: Cameras, TVs and Players (https://www.digitalfaq.com/forum/home-video/)
-   -   Go Dual Deck VCR question. (https://www.digitalfaq.com/forum/home-video/867-dual-deck-vcr.html)
WEW3 07-18-2006 09:11 AM
Last week there was a power outage on my street,(some stupid idiot got a Mylar balloon stuck in the power lines). I had to reset everything on my GO Dual Deck VCR. A week later I still can't get certain functions to work on my remote control(volume on tv and vcr, switch from deck 1 to deck 2 and the mute button). I've done the usual tricks like unplug vcr for about 15min reset vcr and take batteries out of remote put back awhile later, new batteries etc. Still can't get other functions to work on remote. Not a major problem, but help would be appreciated.
markatisu 07-18-2006 09:15 AM
Is there anything in the manual that says how to reprogram it, like entering in a code or anything?
WEW3 07-18-2006 09:43 AM
It basically said to do what I did. It says that remote may not have use of all the functions. That would be cool, but it worked for the last four years. There's only one code for my Magnavox tv, so that's the one I used. Can turn tv off and on, but that's it. I can do everthing still, but I have to get off my butt to get to the tv or vcr for certain functions. lol
MagnificentMarcus 07-18-2006 12:44 PM
Yeah, I'm having problems with mine too and I'm right around four years. The remote won't turn the TV off or on, and I can't switch back between decks. The only way I can switch to the other deck is to eject the tape in the other deck.
stoogedog 07-19-2006 04:34 AM
hi, having a problem here with my go dual deck remote as well. i can't get mine to do the display function. that is the only function not working. thanks
WEW3 07-19-2006 07:26 AM
Marcus, can you still switch decks by going to the vcr and pushing the deck button? That's how I'm doing it now. Your way works too.
I'm not sure what you mean about the display function Stoogedog. The whole vcr won't work unless you do the inital set up stuff. I do know there is actually an option that you can turn off the display graphic in the menu. It's there, but you just can't see it. Much like you can make the clock dim or bright if you want. There's a menu button on the vcr.
Looks like the remote control has a shorter shelf life than the vcr.
stoogedog 07-19-2006 10:05 AM
hi, on the remote, there is a display button. when you press it, it will display on the tv screen info for both decks. i used it to check running time etc during transferring. now that function on the remote doesn't work. thanks
jenstewart 07-19-2006 10:53 AM
What irritates me about my Go Video is that deck 2 tracks wonderfully, while deck 1 doesn't track well at all anymore.
WEW3 07-20-2006 06:47 AM
Yeah I've noticed that when playing back tapes that were recorded on another recorder it tracks better on deck 2 than deck 1. Sometimes I playback by connecting my JVC vcr through the input jacks of the GO because I have better tracking functions.
Tcel93 07-20-2006 09:13 AM
Geez, my deck 2 hasn't worked in a long long long time. Broke almost as soon as I got it :) I remember back in the day I purchased like 10 of them in bulk for a great price then sold them off on onsale.com. Those were the days....
