Wanted: Supermediastore.com 1000-case storage for CDs/DVDs
A number of months back supermediastore.com used to sell a 1000 case aluminum dvd storage container. They have not had (and seemingly no longer sell) the 1000 case editions (only 600 is available now). The problem is that all of the similar type of cases that can be currently found on Amazon and Ebay are slightly smaller in size than what supermediastore used to sell (if I cut off the top of the case from the SMS one, the newer units can actually fit inside it). This resulted in going from 250 discs per row (of 4), to only holding 236 per row (unless you crush them with a vice grip). In the end 944 is a big enough difference for me that claiming it can hold 1000 is total BS.
If anyone bought one from supermedia store and for whatever reason no longer needs or wants it, please get in touch |
Is this what you're after? --
SuperMediaStore 1000 Disc Capacity Aluminum-Like Hard Plastic with Wheels Black CD DVD Storage Case Price: $63.99 & this item ships for Free Standard Shipping In Stock, Usually leaves our warehouse in 1 business day(s). Estimated Arrival Time Also... $3 Off $30 Orders with coupon a8201b0c |
Thanks for the tip. It is close, but I would need to mod the case for it to be stackable.
The one I was after was this: http://www.supermediastore.com/produ...case-cbs1000bk |
