07-20-2007, 10:52 AM
MagnificentMarcus MagnificentMarcus is offline
I have a two External Pioneer DVR- 111D DVD Burner which just stopped burning, and they keep giving partial burns. They will be burning fine and all of a sudden it just slows down and then stops. It's running and everything seems to be functioning. I have all programs disabled. I have run spyware (Adware & Spybot) and virus programs-nothing found.
I've changed power cords, hooks up and everything. Still the same problem! I know these Pioneer DVD burners are worthless, but I have two of them that I bought at the same time and they both are doing this!
Anyone have any ideas?
07-20-2007, 02:28 PM
Dirty? Clean them by dismantling and swiping with a q-tip dipped in 70% isopropyl "rubbing" alcohol. Then a quick swipe with a dry q-tip. Be super gentle. Do not using a "cleaning" disc.
Maybe remove them from the device manager, reboot, and let Windows re-find them.
07-20-2007, 03:18 PM
Done the device manager deal, didn't work! If they were dirty why would they stop at 30% and 75%?
07-20-2007, 04:22 PM
manthing manthing is offline
could it be that batch of dvd discs you're using?
i went through a similar problem but could not find a reason.
maybe its the software?
are you using nero?
try some other burning software.
not much help am i?
i think the simple answer is to plonk down another $30 and see if the new burner works on your system. which may or may not point to the other 2 being faulty.
07-20-2007, 06:43 PM
I'm using Taiyo Yuden 8X-R (Premium) discs. I've been using DVD Decryptor and ImgBurn burn programs to burn.
DVD Burner jrnyhead Blank Media 3 01-17-2009 03:21 PM
Recommend a DVD-burner? Scott Blank Media 13 01-24-2008 07:37 PM
Pioneer DVR-109 burner and problems when burning rmehta2 Copy DVDs, Duplicate, Replicate 1 11-01-2006 09:23 AM
DVD burner going bad???? MagnificentMarcus Copy DVDs, Duplicate, Replicate 14 08-09-2006 05:07 PM
Dvd burner help d.smyth Blank Media 3 02-15-2006 05:33 PM
