ehbowen |
12-20-2020 08:32 AM |
1 Attachment(s)
Originally Posted by gamemaniaco
(Post 73423)
I'll buy a DVD reader / writer drive to store it and read and burn my discs in the future because the drives will no longer be manufactured, do you recommend buying an internal or external drive to use in the future? should i buy a CD and DVD only or bluray drive? I have MDisc and Verbatim AZO DVD discs
Check the media manufacturer's list of drives which they consider to be compatible with their products and select from those. It isn't fair to ask LS to recommend a specific drive; suppose you buy it and it turns out to be that ONE off the production line which wasn't up to snuff?...you'd blame him. (Yes, you would!)
Internal or external depends simply on your hardware and budget; the internals of the drive mechanism itself are likely to be similar for each manufacturer. If you have a tower computer with a free SATA port and open 5-1/4" drive bay then buy an internal if you can find one on the list which suits your tastes and budget; otherwise purchase an external.
Here's my recommendation, GM...if you're really that concerned, buy TWO burner drives. One Pioneer, as LS recommends, and one LG compatible with Blu-ray. Make multiple copies of your precious DVDs (you should, anyway) on three or four different kinds of media. Fifty years from now you can come back and tell us which ones best withstood the ravages of time and the humidity of the jungle.
Here's the compatibility list from Verbatim for M-Discs: Verbatim M-Disc Compatibility Chart.
