Quantcast Black-purple line near edge of disc? - digitalFAQ Forum
01-18-2022, 03:17 PM
minus2x4 minus2x4 is offline
Hi, I was burning about 100 or so discs and noticed 5 or so have this black or purple looking line near the edge of the disc. It's sort of a half circle shaped. Copying files from the disc, read, scan, and quality tests look fine, so I wondering what this could mean? I attached a picture, although my camera isn't the best.
01-25-2022, 05:27 AM
Probably missing dye, or dye defect, or dirty disc when burned, not good, bad burn or disc.
01-25-2022, 08:31 AM
dpalomaki dpalomaki is online now
What brand discs?
If the burns tested good, how much content did you put on them? You might find trying to use 100% of the rated capacity disc doesn't work, that you only have say 96% available for content before burn errors.
What is this edge ghosting called? juiceycow Restore, Filter, Improve Quality 0 03-01-2021 10:44 AM
Yellow line at right edge of capture? Okiba Restore, Filter, Improve Quality 8 09-08-2020 03:56 AM
Possible to eliminate or calm down edge ghosting on Hi8? cbehr91 Restore, Filter, Improve Quality 0 04-26-2020 01:34 PM
ATI Dongles - Purple and Otherwise Joekster Capture, Record, Transfer 7 01-31-2015 07:02 AM
Player can't read disc anymore? BD-R 25GB movie disc error kpmedia Blank Media 0 12-07-2010 11:45 PM
