02-13-2004, 12:10 AM
My preference list, in 2004, in order:
... the best, usually flawless
PVC (-R)
MXL (-R) ... be aware of fakes
MCC (-R)
TDK (-R) ... be aware of fakes
TAIYOYUDEN (-R)
PRODISC (+RW)
... normally pretty good, not flawless
RICOHJPN (+R)
RITEKG04 (-R)
OPTODISC (-R)
RITEKG03 (-R)
... only if I must, okay success rate
PRINCO (-R)
LEADDATA (-R)
... when hell freezes over, landfill material
AN31 (-R)
PIODATA (-R)
ACCU (-R)
MATRIX (-R)
LONGTEN (-R)
OPTODISC (+R)
CMC (-R,+R)
02-18-2004, 04:47 PM
indolikaa indolikaa is offline
Indolikaa's Preferred Media is based on the following factors:
* Failure rate, which is based on a minimum of 50 discs,
* Compatibility with multiple generations of DVD players,
* Ability to produce successful burns only at rated speed,
* Multiple distribution sources, which suggests uniform production methods and accurate Media IDs.
(NOTE: Indolikaa automatically awards a failing grade to any disc if pixelation begins prior to the 4.0GB benchmark.)
THE CURRENT WINNERS...
Taiyo-Yuden DVD-R 2X (TAIYOYUDEN)
Why?
I have yet to coaster any of the hundreds of Taiyo-Yuden DVD-R discs that have passed through this authoring station.
Memorex DVD+R 2.4X (RICOHJPNR00)
Why?
With a failure rate of 1:35, this is the most consistent DVD+R media I have purchased. These discs were purchased in jewel-case 3-packs from Wal-Mart; they are known as the 'Purple' packs due to their purple packaging.
Memorex DVD+RW 2.4X (OPTODISCA01)
Why?
A failure rate of 1:50 is most impressive for any rewritable media, but these discs have proven to be outstanding for multiple erase/rewrite cycles. I have five of these discs in which each disc has been subjected to over 200 erase/rewrite cycles, with no apparent deterioration in quality. These are the 3-pack jewel-cased 'Yellow' packages available at Wal-Mart.
THE CURRENT LOSERS...
Verbatim DataLifePlus DVD+RW 2.4X (MCC A01)
Why?
The 'First-Burn' failure rate for this media has been 1:5, with none of the surviving discs lasting beyond 15 erase/rewrite cycles. With multiple purchases of both the single jewel-case and 10-pack jewel-case SKUs from multiple vendors, it was initially suspected that the trio of Optorite burners (firmware 2.16, 2.17 and 2.50 respectively) might be at fault.
However, subsequent off-site testing with both a Sony DWU14A and an LG GSA-4040B have reported a similar failure rate.
AND THE JUST-PLAIN EMBARRASING...
CompUSA DVD+R 2.4X (OPTODISCOP1)
Why?
A failure rate of 1:3 from batches purchased at multiple retail location and burned on multiple burners. The first four 5-packs appeared to be fine, but then it all went downhill from there...
Nuclear war is the continuation of politics through more efficient means.
Welcome to the digitalFAQ.com!
12-08-2004, 01:28 AM
dminches dminches is offline
Originally Posted by admin
My preference list, in order:
PVC (-R)
MCC (-R)
TAIYOYUDEN (-R)
PRODISC (+RW)
What brand names do PVC, MXL and MCC get sold under?
12-08-2004, 08:27 AM
PVC = no longer sold
MXL = Maxell DVD-R "made in Japan"
MCC = Verbatim DVD-R "made in Taiwan"
... at least as of today (Dec 2004)
12-15-2004, 05:37 AM
strangepork strangepork is offline
meritline has a good deal on ProDis - r. I have successfully bought from them 3 times. Ive tested out the ProDisc 4x pioneer certified Azo dye and its worked on every dvd player so far(6 tested). Expect a 14 minute wait to burn a full dvd.
Second on my list is the ProDisc 8x + r. It doesnt have the "certified" jargon, but it is the company. Write time is about 8 minutes (im getting spoiled), and has been played on 2 dvds players succefully.
my player that has played nearly everything ive thrown at it, is the Phillips DVP-642. All region, converts pal to ntsc (decently, but not perfect), and divx.
hope this helps
12-15-2004, 06:15 AM
TY and MXL media has frequently been on sale in stores in November/December 2004, averaging about $10 per 25 discs. Not bad for 1ST CLASS media. Though I still buy a lot of media online, I've been hitting up stores quite a bit too.
Any VCR suggestions specific for 2009? via Email or PM Capture, Record, Transfer 1 09-08-2009 10:28 AM
Capture Card Suggestions with Vista 64 bit cgcarter Capture, Record, Transfer 6 12-28-2008 01:03 AM
UK media suggestions lordsmurf Blank Media 2 06-09-2007 06:42 PM
Portable DVD Player suggestions!!!!! MOTUfan Videography: Cameras, TVs and Players 3 11-21-2005 03:51 AM
TV suggestions? MOTUfan Videography: Cameras, TVs and Players 9 10-21-2005 04:18 PM
