Quantcast Verbatim DL Types & Burn Speeds? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > Blank Media
03-28-2009, 09:16 PM
Altek Altek is offline
I noticed two types of Verbatim DVD+R DL media. I saw Verbatim 2.4x-6x and 8x-10x. Which speed Verbatim DVD+R DL media should I buy? At what speed should I burn? I use ImgBurn.
03-29-2009, 03:35 AM
There is really no definitive answer here. Much of this depends on the DVD burner in use.
For example, I mostly use a Pioneer 111 drive for burning DVD+R DL media. In this drive I primarily use the 2.4x-6x discs, Verbatim made in Singapore, and burn at either 2.4x for master/archival discs, or 4x for duplicates for others. The 6x burns are always rotten quality, if the burn even succeeds. The 4x burn speed has a higher coaster count too, than the 2.4x speed, maybe 1 in 20 at 4x, instead of 1 in 50 at 2.4x.
Ideally, I'd think a 8x DVD+R DL would work great at a 4x or 6x burn speed, but whether that disc can be burned that "low" depends on the burner and firmware.
The most I can do here is share what I do.
__________________
Read these 3 DigitalFAQ Notes:
1. You must be logged in to see images or download attachments. Not a member? Register now!
2. Like this site? Did my writings help you? Then upgrade to a Premium Membership or give a small Donation. Also Like on Facebook or Follow on Twitter.
3. Discuss television shows, cartoons and DVD releases at the TVPreservation.com Forums.
Software can read and burn better than others? wheezer210 Copy DVDs, Duplicate, Replicate 1 11-07-2006 12:28 PM
How do i download so i can burn to disc stoogedog Web Streaming Video Help 5 10-11-2006 05:27 AM
Types of Copyprotection Tom_n_Jonna Restore, Filter, Improve Quality 2 01-19-2006 08:23 AM
Bad burn with Fuji Taiyo Yuden, what could have gone wrong? MagnificentMarcus Blank Media 18 09-14-2005 06:42 AM
How to burn extras onto a DVD markatisu Author, Make Menus, Slideshows, Burn 0 06-02-2005 10:00 PM
All times are GMT -5. The time now is 03:48 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
